Can I get rid of this thing on my vacuum line?
Whily topping off my A/C system today I noticed a sucking sound. I looked at the vacuum lines coming from the intake manifold of my 3.0. One of them has a little device in the middle of it - orange plastic thing with the vacuum line hooking up at each end. I found a small piece of missing plastic from one edge of it and that is where the vacuum leak is. I looked inside and there is a spring so I'm assuming there is a diaphragm. Where would I get one of these? Is it a valve of some sort? Can I just connect the two ends of that vacuum line together?
thats a check valve--right? ( does it look like one? ), it should only have one in and one out, orange on one side. you need that piece by the way, i would just replace it with another one.
T
T
TokyoD23
07-12-2015 06:01 AM
