| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Can I adjust my clutch?
#2 (permalink) | |
Do you have to push it ALL the way to the floor for ALL gears? I commonly have to do this for 1st and reverse only.
__________________
1998 SR5 4WD 3.4l V6 5SPD Dealer Options: 4.10:1 RR Diff Lock; Brush Guard w/ Hella driving lights [removed] Mods: Thule Roof Rack w/ Canoe Gunwhales; Silverstars; Bridgestone Revo 265/75/16s; Maglite mod; Deckplate mod; Stickers! Wishlist: TJM T-15; Custom rear bumper; 2" suspension lift; Satoshi mod; Gray-wire; Sliders; Full length skid plate; etc Quote:
#3 (permalink) |
I think thats what is happenin with mine too. It seems to shift sooner than the floor once im goin.. I wonder why?
#4 (permalink) |
According to the chilton manual, there are 3 different clutch adjustments - pedal height, free-play and pedal pushrod play. I don't have the manual on me right now so I can't tell you how to do the adjustments, but maybe there's too much play somewhere...
it could also be that the clutch slave cylinder is going out. I had an explorer that the slave cylinder went out on and I had pretty much the same problem you guys are having. With the slave cylinder going out, the clutch wasn't fully disengaging making it hard to shift into gear while stopped. But once I got moving again, shifting was fine. Only thing with the explorer though, is that you have to drop the transmission to get to the damn thing... what a pain that was. On the 4runners, the slave cylinder is on the outside which should make it pretty easy to change. also, check the fluid level. If it gets too low, air will start getting into the lines. this article might help... http://www.4x4wire.com/toyota/mainte...chmaintenance/
__________________
-chad- 2000 4runner SR5 4wd 5sp | 1" lift pp coils | ARB bumper | 265/75/16 MT's on american racing wheels | detroit locker | deckplate, MIT and AMSOIL | magnaflow exhaust | Lars's discos | extended diff breather | yakima roof rack | Last edited by mtxride; 06-23-2006 at 08:02 AM. |
#5 (permalink) |
also i just went and looked at my fluid, it doesnt seem to be low but it is kind of brown lookin... would old dirty clutch fluid affect the performance of it? I am goin to change it tonight..
#6 (permalink) | |
Quote:
__________________
2000 V6 TRD 5spd | 1.5" body lift; 2.5" sus lift: SAWs, 8leaf deavers, downey shackles, bilstein 5125s, 32" BFG AT's | Magnaflow 18" muffler, Hella 500s, bentup sliders, polar bear guards, aluminum diamondplate skidplate, clear corners & bumper lenses, tonneau cover | deckplate mod, disable DRL mod, greywire mod, extended diff breather, clutch pedal mod |
#7 (permalink) | |
Quote:
That was my experience in my F-150 when the clutch master cylinder went out. I had to push the clutch to the floor to shift into any gears, and the pedal didn't feel as solid as it had before. I replaced the clutch MC and that fixed everything. 'course this is in an F-150, so take it for what it's worth. |
#8 (permalink) |
Air in the clutch hydraulics will cause exactly the problem you describe. I'd start the diagnostic process by bleeding the clutch.
__________________
-Karl '03 Titanium Limited, 4WD, V-8 Ex '98 4Runner Limited 4WD auto '07 Porsche GT3 '88 Porsche 911 (For Sale!) |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| how do you adjust the speedo? | Sonofmayhem | 86-95 Trucks & 4Runners | 8 | 02-22-2007 05:16 PM |
| Clutch Adjust revisited | rdharper | 86-95 Trucks & 4Runners | 12 | 10-27-2006 08:08 PM |
| Can I adjust a 91 clutch? | Fo by Fo | 86-95 Trucks & 4Runners | 4 | 06-23-2006 12:24 PM |
| how do u adjust camber? | chugs | Newbie Tech Section | 7 | 05-22-2006 07:49 AM |
| 3.0 Valve Adjust | Elvota | 86-95 Trucks & 4Runners | 1 | 01-10-2006 03:48 PM |
