cambered wheels after lift
i lifted my runner 2.5 inches with spacers and now the front two wheels camber in at the bottom... what can i do to get these straight again? is there any extension i can get for something, any help would be awesome. thank you
I just noticed you are in OKC. Jackie Cooper on NW expressway is a good place to get a 4x4 alignment. That is where 4WPW sends their lifted trucks for alignments. They have those new 3D laser machines there. They aligned mine after I put my ball joint spacers in and got everything within Toyota specs.
yup the camber needs adjustment.. if you can see they have positvie camber, im willing to bet you have a minimum of 2* positive camber and that can lead to messing up the tires in only a couple thousand miles.....
if i cant adjust is there a camber kit? that will extend the stressed pieces? i really have no clue about any of this....and haven't been able to talk to my dad about it yet.
just need as much help as i can....
on most vehicles where there is uca adjustment points there may be no kits available, however if the cam bolts that secure the uca to the frame are already maxxed out of adjustment, some places can modify them to get them within specs... some vehicles can use a method of slotting the holes and some use aftermarket bolts with differnt washer plates
got my cams adjusted and aligned today.. thank you for all your help
jackie cooper is awesome only costed 69.99
Flying91
45
04-11-2024 04:39 PM
coffey50
07-28-2015 10:55 AM
skoti89
07-06-2015 07:45 PM
