Camber way out?
Old 05-06-2012, 05:59 PM
Doug18's Avatar
Camber way out?
Hey guys I did a search but turned up little results.
I noticed that my camber appears to be wayy out today ... I installed OME suspension and got it aligned afterwards but I am really wondering if they did a ****ty job or if the cam is just maxed out in its adjustment
The camber is noticeably out when looking at the truck head on and it is pretty bad IMO because the inside ~1" of the tire seems to barely contact the road (stays dirty)
Old 05-06-2012, 06:04 PM
rworegon's Avatar
What does the before and after alignment report show?
Old 05-06-2012, 06:12 PM
Doug18's Avatar
not much change a little ... but not much dont remember the numbers off the top of my head
Old 05-06-2012, 06:23 PM
rworegon's Avatar
The question is really were the after settings within the spec range for your rig.
Old 05-06-2012, 06:53 PM
Kiroshu's Avatar
You installed suspension parts...? Details on that maybe...
Normally on these trucks even when they are lifted the Ecetric Cams on the control arms are so large that they allow for large adjustments for a very long time...
However the most common issue for these Cam bolts to stop adjusting is for the bushing the thy move(Lower control arm bushings) wear out and allow for minimal adjustments once this happens... Replace lower control arm bushings and align.
Old 05-10-2012, 07:51 PM
Doug18's Avatar
Got it adjusted and rolling nice now ... the alignment shop apparently had a F@#* tard working the first day I took it in and my issue was quickly addressed and sorted when I took it back in
Old 05-15-2012, 07:38 PM
skjos's Avatar
I had the alignment done right after the lift, and then I needed it redone after the new springs (OME 881) settled.
Old 05-16-2012, 06:08 AM
Nelsonmd's Avatar
Glad they fixed it. You can check this yourself though. I gave myself an alignment last weekend when I overhauled my front end, and I got within 0.1° for toe with just a tape measure. Camber is a little more difficult, but you could do it with a level and something to square up against the wheel. If the guy really did screw it up that bad, it should be pretty easy to figure that out with a level.
Old 05-16-2012, 06:31 AM
Doug18's Avatar
yea, the truck was visually out of camber it was sitting like \ /
Old 05-16-2012, 06:40 AM
250000_yota's Avatar
As an alignment tech, it sounds to me like they just did what we call a, "toe-and-go." Meaning, the lazy jack wagon pulled your truck on, looked at the numbers, said to himself, "camber and caster dont look tttthhhaaaattt bad...I'll just set the toe and see how it drives." Lucky for him, your truck drove straight. Unfortunately for him, you noticed. Like I stated above, I am an alignment technician. That's at least 50% of my job. It really makes me kinda sick seeing my colleages pulling this kind of crap. My suggestion to you and everyone else on this page is that when you go to get your car or truck aligned, watch from the bay door or office window if you can, and ask for a print out of your readings with before and after graphs.
Project90
09-24-2015 11:40 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
Ernie217
08-14-2015 05:25 AM
bamachem
48
07-07-2010 09:21 PM
fatdudesurfin
09-16-2005 11:47 AM
Quick Reply: Camber way out?
