Cam sprocket removal
Found a leaking cam seal along with a leaking crank seal. I know there is a SST to hold the sproket so you can break it loose. Does anyone make a knock-off of this tool, or is Toyota the only one that carries it? Has anyone used a chain wrench? I was thinking maybe a chain wrench with a piece of old timing belt so the teeth don't get damaged.
Also..any good way to get these seals out? I tried to get the crank seal out with a small screwdriver, but gave up for the day. Thanks for any help...
Those bolts are hell.
See this thread for more info:
https://www.yotatech.com/forums/show...ead+gasket+set
Here's the tool I was going to buy:
http://store.autotoolexpress.com/uncamad.html
I Finally ended up making my own tool with a long peice of 3/4" square tube as the handle and 2 peices of angle iron that fit in the sprocket as the teeth (I think I could have used thick bolts in place of the angle iron for teeth) . With the sprocket held in place I used a 1/2" breaker bar and a cheater pipe to get the bolts out.
Sam
Sam
Thanks for the help. I just ordered that same tool about a half hour before reading this...since it looks like both seals are leaking. I thought the same as you, using angle iron and bolts. By doing the repair myself I figure I can buy a few tools and still be way ahead money wise. So far it hasn't been too bad...but it sounds like getting those bolts loose will be lots of fun. Thanks again for the help...appreciate it.
I changed the cam seals on my '89 Supra Turbo. Be sure to lube the seals with oil before you install them, if dry, the inner lip may fold over as you press it on, and it'll leak again. Good luck, keep us posted.
Just a little bit of assembly grease on the seal and crank before install will prevent that completely.
Also if the seal is not lubed at startup it may see excessive wear before getting lubrication.
I used a strap wrench you can buy at Walmart or any auto parts store. It's the rubber strap with plastic handle. It worked for holding the cam sprockets in place as well as turning over the main crank when the main bolt is not installed.
The tool came in handy for breaking loose the rear shocks from the locking nut on top.
J
J
J
J
heres what i did, since i was putting a new timing belt on anyways, i just used it to protect the teeth on the gear, used big pipe wrench, and put a piece of pipe on my breaker bar for more leverage, and it came right undone. i think spec is like 80 ft/lb. i thik it took a good 250 to get them off.
Wow! Great idea! My neighbor across the street does HVAC work, and he has a pipe wrench that size. What's worse is I'm over there quite a bit when he needs help with the '69 Roadrunner he is working on...never thought of borrowing his plumbing tools. Guess my wife is right...she always says if you want to hide something from me, just put it right in front of me. Thanks for the picture.
If you are going to use a strap wrench, get a decent one like this:
Those crappy plastic ones they sell everywhere are total junk and will break in a second when used like you want to.
A chain wrench will also work great but be sure to protect the cam gear from damage by the chains.
http://www.zealtools.com/browseprodu...ey-Holder.HTML
Originally Posted by oreomiddle
That strap wrench does not work for crap.Bought an identical one and no dice.Here's a link for what you need.Only 40 bucks. Works like a charm.
......also you need to use a piece of rubber around the cam to help it grip for the strap/chain wrench.
You obviosly don't need the tool at all if you have access to an impact gun.
That is the correct tool, the strap/chain wrench is only if you are in a bind and don't have access to a cam pulley tool.
You cannot retorque it correctly when reinstalling without the tool.
spanner wrench arent that expensive. it works great for the last several times i had to work on the front-side motor.
