Cam Problem....3.0 builders please look!
Old 10-14-2005, 07:11 PM
callmej75's Avatar
I ran across this tonight when I was sealing up the end bearing caps. Will this be a balance issue in the cam? If so could I possibly take my cam, shims, and bearing caps out of my old head and put it into the reworked one? I bought these reworked heads off ebay....
Old 10-14-2005, 07:14 PM
jimbo74's Avatar
does it actually look broken off? maybe it was removed on purpose... that cam looks rusty, i wouldnt trust that.... jsut replace it now with a hi-po cam
Old 10-14-2005, 07:16 PM
callmej75's Avatar
Check the front of the cam where the lip is behind the bearing cap...about an inch of it broken off.
Old 10-14-2005, 07:23 PM
jimbo74's Avatar
i did look thats why i am asking... your pics are very hard to tell if that missing section was purposely machined off for balance issues or if they dropped the cam and it snapped off
Old 10-14-2005, 07:26 PM
callmej75's Avatar
I pulled my old cam out of my old heads and it has a lip all the way around. the edges of it look filed so it wouldn't score the bearing cap. It looks like it was dropped...because you can see the inside of the metal where it was chipped off. Not machine work...by no means
Old 10-14-2005, 07:54 PM
callmej75's Avatar
Is this better?
FilthyRich's Avatar
WTF I can't F---- believe this. I never opened them. then went from the post office to the DHL office. Man....I paid with paypal, and have yet to leave feedback. Once again, tell me what you want to do. Damn FLE Bay
Old 10-14-2005, 08:09 PM
callmej75's Avatar
Yeh its not your fault dude...I think the guy knew what he had and decided to get rid of the headache. I contacted strap22 and he is gonna have his techs on it in the morning. I would request some money back. I think you have 30 days after purchasing to request something back. But you guys go have fun this weekend....we'll take care of this Monday Oh yeh...if I pay thru paypal will your wife cook me some homemade chicken noodle soup!
Old 10-14-2005, 09:34 PM
engnbldr's Avatar
>>>*Hi! Got the email on this one. That isn't a chip, it's a chunk. My feelings are that it will shave metal off the head, if it was mine, I would replace it.
*Never saw this before, did that get dropped or something? I can't imagine it running that way....*EB
Old 10-15-2005, 04:24 AM
Sponsoring Vendor
Strap22's Avatar
Jeremy you are going to have to replace it. That will be so out of balance I would be surprised if it ran at all. I'll PM you the FSM on installing the Cam shaft. Shimming is the problem I see at this point. Between the 2 heads you may have enough of the right shims to get it set-up. I am waiting on our Master Tech to get in and I'll show it to him and get his take on it. I would file a claim with UPS for the damage. I hope you insured it. Get back to you in a little while............
Old 10-15-2005, 04:32 AM
callmej75's Avatar
Yeh I should have enough shims. I never saw any chips in the box...but I'll look again this morning when I get to the shop. I'll give ya a call a little later on. Filthy shipped it DHL so its between them and the USPS because the seller from ebay shipped it thru the postal service. Appreciate the help buddy
Old 10-15-2005, 04:52 AM
Localmotion's Avatar
Old 10-15-2005, 01:41 PM
kyle_22r's Avatar
i wouldn't be worried about balance so much as the fact that the broken part will gouge out the thrust surface in the head.
Old 10-15-2005, 03:02 PM
callmej75's Avatar
Heads taken care of...I used my old cam and shimmed them up and measured the shims and they are within .011"
Old 10-15-2005, 07:38 PM
gonzo's Avatar
cam problem
Reading this post iI just had to post this to give you guys a laugh.
I got a friends yota here with the 3.0 he just bought. Had an oil leak on the front of the motor.
Finally found it to be the right frt. cam seal.
Got it apart and found someone had put a sealer on the rubber seal where it meets the cam. It stuck the seal to the cam good enough that the seal started turning in the head. Now the new seal won't stay in the head as the old one wore the alum. head where the seal sits. I'm trying now to find a seal that will stay in the head.
lol. some of the things ppl do.
Old 10-16-2005, 02:07 AM
Ganoid's Avatar
What causes that cam damage is pulling the cam bearing caps off with the cam in the wrong position. you need to have the cam in its "at rest" position before taking the caps off. That is what occurs when a valve spring pushes one end of the cam up while the other is still in the bearing. Its common from what the guys told me at "Oregon cam grinder" when I took a used set in to be ground. I ordered a set from "Toyota parts guy" and one of them was broken just like yours. I was able to get 2 good grind-able cores out of the 4 cams I had so all was good.
LittleUgly
15
01-02-2020 01:30 PM
moparbay
10-06-2015 09:24 AM
tylermx71
09-29-2015 08:49 PM
whiteyota93
09-29-2015 02:31 PM
voiddweller
09-28-2015 11:21 PM
Quick Reply: Cam Problem....3.0 builders please look!
