CALLING ALL SMART 1st GENERS
My bright's on my 87 4runner havent been working for some time. I have to get it fixed before I can renew my registration. I already replaced the headlamp switch in the steering column but that didnt help. Mechanic says its the combination switch which runs about $200 from the dealer. Anyone have experience with this problem or know of another way to get this part besides the yota dealer. I searched this already but didnt get a good answer.
Thanks y'all
Andrew Berglund
Thanks y'all
Andrew Berglund
By combo switch does he mean the turn signal/headlight switch that's under the shroud? I've never heard of that problem before but definatly check out the salvage yards first. Try to find a 'pick-n-pull' to save some extra coin. Not positive but the same year pick up should be the same part. I think the relays and fuses control low and high beams so the combo switch sounds about right. Good luck.
I've had this problem 3 times now....
Heres your quick and easy solution:
http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
You can thank Roger for it!
http://www.4crawler.com/4x4/CheapTri...OnLineOrdering
justdifferentials
14
06-11-2017 08:36 PM
runnermedic
13
09-21-2015 05:20 PM
icentropy
09-10-2015 05:03 AM
Badfish740
09-04-2015 04:21 AM
