Cable diff lock / for Elocker
Old 10-20-2009, 07:32 AM
danielharro's Avatar
I have a 2000 4runner with an Elocker (which currently does not work because the actuator motor is toast) and I am looking for a cable or manual mechanism to replace the actuator motor any help? I think Downey Off Road used to make some, but it seems like they are out of business? Any one else out their making any? I have been unable to find a motor....
Old 10-20-2009, 07:52 AM
ozziesironmanoffroad's Avatar
ask deathcougar, he can get you any toyota parts u need.
Old 10-20-2009, 09:03 AM
crolison's Avatar
I just converted my own actuator to run with cables.
Old 10-20-2009, 09:08 AM
Teuf's Avatar
OK Crolison, and how did you do that, parts from whom?
Old 10-20-2009, 09:13 AM
How did you do that? Any photos? Thanks!!
Old 10-20-2009, 09:27 AM
Midget96's Avatar
Whats wrong with the motor? I thought mine was screwed, but there's really nothing that can break on these things. Mine didn't work for over a year. About an hour of fiddling with it and it was good as new, probably better.
Old 10-20-2009, 10:21 AM
Here is my original thread:
https://www.yotatech.com/forums/f2/2...r-help-185185/
through this I came to the conclusion that my motor is toast. Unless you have any other ideas.
Old 10-20-2009, 10:30 AM
crolison's Avatar
here ya go
https://www.yotatech.com/forums/f2/e...ersion-189134/
Old 10-20-2009, 10:49 AM
Nice work!! It might be a litte too much for me. I don't have or really have ever done much with a welder or really with metal of any sorts. I remember seeing a manufactuerd one somewhere that was simular but involved taking the motor off and replacing it with the commercial pieces. Their has to be a company out their making this thing still.
Old 10-20-2009, 11:10 AM
Midget96's Avatar
Where's the gear at? It's missing in the pic. If it's gone or fallen into the diff, the motor is junk and you probably have a bigger problem on your hands.
But I still think that motor is salvagable. Just fix the hole with fiberglass.
There's a thread on TTORA where a guy fixed a hole in his and refubished it to run perfectly.
Old 10-20-2009, 11:51 AM
Its hard to see the gear in the photo, but its their. Over time water got into the housing and as I was cleaning it I made a hole and rust water poured out, I think the gear is seized up and no longer works and the unit is too rusted to take anything apart to fix it. I am just afraid that if I get it apart I will destroy it in the process and then be forced into buying a new motor from toyota at $800 bones...
Old 10-20-2009, 12:06 PM
I found the rebuild links and I bet it would work for mine, still nervous though.
Here are the links incase anyone is interested:
Pirate4x4
TTORA
Old 10-20-2009, 12:24 PM
Fossilized
Staff
dropzone's Avatar
here are some from pirate:
http://pirate4x4.com/forum/showthrea...ble+conversion
Originally Posted by DWT
This is the setup off of my old axle. I can't claim to have done anything but install it but it is stone simple to build. The only thing I'd have done dfferently was use a better cable that the pos pto cable it came with.
marlin's forum:
http://board.marlincrawler.com/index.php?topic=5003.0
HaukurU
08-03-2015 02:40 PM
dfarr67
07-30-2015 07:08 AM
Daneums
07-28-2015 11:57 AM
Athansinis
07-27-2015 08:38 AM
Steven.m.paulk
07-24-2015 01:44 PM
Quick Reply: Cable diff lock / for Elocker
