In cab tire deflation / inflation..
Hi guys,
Some guys here have a system for doing that, and they can monitor the pressure in each tire from inside the truck, and also deflate or inflate.
Now I'm wondering if there is a kit out there to do this ? Something that I could use on my toyota ?
I think most of the guys here that have this sort of stuff, have had it made here. And it is expensive stuff..
I already have an A/C pump, airtank, pressurestat in my truck.. so I can manually inflate the tires.
This guys adding 404 Mog axles and central tire inflation to his 4runner:
http://www.pirate4x4.com/forum/showthread.php?t=306807
Yep, usually you need a portal axle setup, since it is easiest to feed the air supply in via the center of the spindle. So the original Hummers have CTIS, the Unimogs also have portal axles.
I am adding the pressure monitoring system to my '85, with beadlocks, I want to be able to see if I have developed an air leak while driving. The system I have allows you to set low pressure or high temperature alarms to make you aware of potential problems.
so...
as I thought .. there is no easy way to do this.. just the custom way .. as they do here
It's expensive.. 40k a wheel ( $1 is 62isk ) so I'm not about to do this
Singstar party here at work guys Cheeers from Iceland !!!
Have a great weekend !
My personal website :
http://www.depill.tk
work:
http://www.gopro.net
Later ya all!
work:
Later ya all!
djpg2000
11-11-2020 04:56 AM
