A/C pressure switch location - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 07-02-2006, 06:44 AM   #1
Hi.
I've a problem with my air conditioning and think the refrigerent may need recharging. Could anyone tell me where the pressure switch is and how to by pass it to check if the system is working in every other respect. I understand if the refrigerent is low the pressure switch activates preventing the compressor clutch from engaging.
Thanks.
Type of vehilce: 4Runner, 1996, 3.4L V6, gas.
on.
Jolooj is offline   Reply With Quote
Old 07-02-2006, 09:33 AM   #2
profuse007's Avatar
i can understand you want to do some quick test but you oughta recharge it w/ a kit and try it. its a cheaper insurance than tryin to wear out ur compressors motor/pistons.
you can try it though, its ur car:
cant remember exactly where it is but its along the low-line (big line). two wire switch. not sure how the switch work at workin pressure, normally closed or normally opened. you can cehck it w/ a DMMeter. hope thats clear enough.
profuse007 is offline   Reply With Quote
Wiring help toyotamonster 3.4 Swaps 6 12-30-2016 05:38 PM
1987 Toyota Pickup A/C stumped. stock87yota 86-95 Trucks & 4Runners 16 07-31-2015 11:08 AM
A/C condenser fan ghosts jackiebrownia 86-95 Trucks & 4Runners 2 07-20-2015 10:02 AM
Opinions of Viair Compressor models, or other compressors skoti89 Offroad Tech 3 07-08-2015 01:05 AM
1985 22re a/c install help bryan34w 84-85 Trucks & 4Runners 0 07-06-2015 06:53 PM
Tags
1995, 34, 4runner, 86, ac, located, location, low, pressure, sensor, switch, switches, test, toyota, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
