a/c not working
Old 06-08-2008, 02:48 PM
burton6509's Avatar
a/c not working
turned on the a/c today and no cold air is coming out of it..i was thinking i might have to recharge it...anyone ever have a promblem with there ac before? what do you think is causing this? i only have 56k on it
Old 06-08-2008, 03:24 PM
swaycleveland's Avatar
find the site glass in the front of the truck ( engine compartment) you should see no bubbles bubble mean its low. but honestly after 56k you shouldnt be having a problem
Old 06-08-2008, 06:29 PM
burton6509's Avatar
yeah i no i hope its nothing important.. what does this site glass thing look like?
Old 06-08-2008, 07:49 PM
Staff
DeathCougar's Avatar
56k but on what kind of vehicle? Seals deteriorate over time, so you may have 56k but the seals could be toast just from the effects of time thus causing a leak.
Old 06-08-2008, 07:50 PM
98runner210's Avatar
few things, is your compressor kicking on? if not, it could be many things, low on freon, bad switch, wiring, etc. Second of all if it is low that means you have a leak. Freon isn't something that wears out or needs to be refilled occasionally. look around the compressor, lines and condensor and see if you see an oily film. Generally a sign of a leak. If you are looking the sight glass the compressor needs to be on to be able to see if you have any bubbles. The sight glass is on top of a cylinder looking thing inside the grill right by the passenger headlight. Open the hood, and look straight down.
Old 06-09-2008, 06:08 PM
burton6509's Avatar
it is on a 02 4runner...i will take a look tonight and see if i see/hear anything..
Old 06-09-2008, 10:29 PM
suzukipro's Avatar
I had my 01 sport in for the same type of issue today. They told me the evaporator as leaking and had to be replaced along with some other parts. They called tonight and said it would be until tomorrow as they had problems getting an O-ring to seal and would figure it out tomorrow!? original estimate was for $582.00 parts & labor, I hope that it doesn't grow any larger than that.
Suzukipro
Old 06-10-2008, 08:32 AM
burton6509's Avatar
ok so i turned on the a/c and looked at the glass seal..when i was looking at it it seemed like the liquid would get sucked out of it and then it would fill up with buddles and repeat..so does that mean i am low on it? i look around for 15 min and didnt see any oily film on anything...
Old 06-10-2008, 05:38 PM
yeah u are low. u got a leak somewhere. time to take it to a professional
MO transplant
04-23-2023 11:58 AM
ashersullivan88yota
01-18-2022 05:37 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Johntom240
7
07-13-2015 12:18 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: a/c not working
