Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
A/C help needed!!!
Hey,
I got another problem on my 4runner. This time it is an AC system. I live in Los Angeles and I need a fix fast, cuz it's 110 degrees outside. Here is the problem: when I first start the truck in the morning, the AC blows cold air (even though it could be colder), but if I shut the truck down and leave sitting in the sun for 20 minutes or more, when I start it back up, the AC blows almost worm air. But when I get on a freeway it blows cold again. What could be the problem??? P.s. it's 91 4Runner, V6 auto 2wd |
| Sponsored Links |
#2 (permalink) |
My mechanic said that it MIGHT be:
87240-89127 Rear heater valve But he is not sure. I don't wanna pay $90 for the part & 150 for installation if he is not sure. |
#3 (permalink) | |
Quote:
#4 (permalink) |
I'm not exactly sure how a 91 with factory A/C should work but unless the rear heater is blowing hot air all the time I wouldn't think it would have any effect on the A/C.
As far as the A/C working better on the freeway I would check to see if there is an electric fan for drawing air through the condensor (in front of the rad). If there is a fan it should activate when the compressor is running. Also check to make sure the condensor is clean.
__________________
'91 4Runner SR5 V6 4X4 Auto, A/C (self installed) 4.56, 31x10.5x15 Nokian Vatiiva Tires Taurus fan (removed) '90 4Runner SR5 V6 4X4 Auto, A/C, 4.56 V6 power with V8 fuel mileage I've used Fram oil filters and dino oil in all my stuff for 30 years and never had trouble |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Antenna for 1988 pickup needed, dont want Autozone speacial,PN needed! | Ilovemountains | 86-95 Trucks & 4Runners | 9 | 07-05-2006 06:36 PM |
| Opinions needed.. and an explination needed | Diesel_Freak | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 10-09-2005 07:06 AM |
| Name that switch... (help needed) | CrazyDiamond | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 06-21-2005 06:12 PM |
| HELP needed for what to do next | northfacer581 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 10-01-2004 07:29 PM |
| Help Needed...Panhard Drop Needed? | emptyd | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 09-25-2003 03:58 PM |
