A/C and gauges not working, fuse blowing
Old 05-10-2009, 05:22 PM
kev7706's Avatar
My check engine light came on yesterday while I was driving on the highway. Moments later, my speedo, tach and gas gauge went out, along with my A/C. I checked the interior fuse panel and sure enough the 10A fuse labeled "Gauge" was blown. Everything worked again until I cranked the engine. Then, the same gauges and A/C went out again and the fuse was blown once again. I pulled codes and found a P0500, which is related to the Vehicle Speed Sensor. Anybody got any ideas?
Old 05-29-2009, 11:22 AM
Shirleyda4runner's Avatar
Bump?
I'm going to bump this because the Exact thing happened to me today. Ive checked the seatbelt wiring which is the only thing I could think of because I replaced the front seat not too long ago. Anyone? Any ideas? Theres really not much to go on except maybe someone knows where to look for a short...
Old 05-29-2009, 11:43 AM
kev7706's Avatar
My compressor clutch was causing the short. The A/C shares the circuit with the gauges. I replaced the compressor/clutch and the fuse to fix the problem.
Old 05-29-2009, 12:49 PM
Glad to see that worked for you, unfortunately my problem even happens if the engine isnt on even if I just click the key to ACC. It's an intermittent problem though, I put another fuse in there to roll my windows up (it looks like it is going to rain) and it didnt have any problems. I removed the A/C fuse (the A/C isnt working anyway) just to check the compressor. I let it sit in the socket for a while and nothing seemed to happen, then I heard the POP like 2 minutes after rolling the windows up and the gauges all stopped working. Does anyone know if this fuse is connected to a relay anywhere that could be shorting out?
Old 05-29-2009, 12:52 PM
As a side note, as soon as the fuse breaks, if the door is open with the keys in the ignition (With the 4runner turned ON) the key reminder ding comes back on and is faster than usual. I thought maybe it would help diagnose it?
Old 05-30-2009, 12:49 PM
FogRunner's Avatar
Try unplugging the alternator. I was looking at the wiring diagram today for the charging circuit (3RD GEN) and the RED ignition on wire to the alternator gets its feed from the 10 amp GAUGE fuse.
Take a look at the online FSM under charging circuit. I dunno why but they chose to put the alternator EXCITE off the 10amp gauge circuit.
Hope this helps.
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
bryan34w
07-06-2015 05:53 PM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: A/C and gauges not working, fuse blowing
