A/C expansion valve
Old 07-25-2010, 10:45 AM
craigoryjames's Avatar
A/C expansion valve
Hey everyone. I just replaced my expansion valve on my 96 4runner and have everything hooked back up with a vacuum pulled. I am a hvac guy, but since I did not replace the compressor I do not know how much oil I should add to the system. I have a 1oz. Do you think that would be enough? Thank you everyone for your information.
Old 07-26-2010, 10:29 AM
tunnelmotor99's Avatar
If you didn't lose any oil you don't really need to add any, although adding some with dye would be a good idea. 1 oz should be fine added to the low side.
Old 07-26-2010, 08:07 PM
FogRunner's Avatar
You don't need to add any oil. If you have access to a charging scale charge the system by weight. Even though its got a expansion valve its really finicky about the charge and very easy to end up with a couple OZ too many or too little when charging with gauge/eyeball method.
FOG
MO transplant
04-23-2023 11:58 AM
Sarcazmo
08-15-2015 08:22 PM
stock87yota
07-31-2015 10:08 AM
jackiebrownia
07-20-2015 09:02 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: A/C expansion valve
