buzzing when turn signal is used?
I have recently acquired a buzzing sound from the rear interior of my 90 4runner whenever I use the turn signal. The signals will work 2 or 3 times accompanied by the buzzing and then the fuse for the blinkers and backup lights will blow. This all started after towing a buddy's car recently. I would assume that the towing light connectors are in the same circuit as the turn signals but what is the buzzing? and if there is a short why does it work fine a couple times adn then quit? Ideas, anecdotes? :pat:
Originally Posted by Toyminator
Ive got the same problem, I dont have a solution, but Ive found, if you turn the blinker on just a little bit harder than normal...it doesnt buzz.
does your fuse blow? i need to fix this, i almost got in an accident today. i can't drive super defensively all the time, too much speed racer in my blood even with the 3slow.
well damn
i am going to delve into this tonight so i will let you know if i come up with a remedy. the buzzing sounds like it belongs to something else, like the chimes when you leave your lights on and open the door. i don't know waht it belongs to though.
Dennisx2
08-04-2015 01:26 PM
PopsDad1
07-30-2015 02:21 PM
