Bumpstops
Old 03-29-2003, 01:18 PM
Eighty7ToyTruck's Avatar
Bumpstops
ok, so im rebuilding the front end in my 87runner now, little at a time, and i want to know if i should buy the low profile bumpstops, or just grind on mine? and-has anyone ever replaced the 4 piston 1st gen calipers? is there an upgrade kit available or not? thanks in advance!
Old 03-29-2003, 01:25 PM
Cebby's Avatar
Do the bump stops. It will give your IFS a hair more articulation. I did my 93 recently. Cheap and easy. There is a writeup in the tech section. Your IFS should be really similar to mine.
Old 03-29-2003, 01:34 PM
but why not just grind on them? i mean, its obvious it will achieve the same goal, right? or am i wrong? please help lol
Old 03-29-2003, 01:44 PM
Cebby's Avatar
Why not take them off all together? j/k
I think if you grind the rubber, the soft material left won't keep the components from bottoming beyond the safe distance it should be compressed. The Energy Suspension models are firmer urethane and will cushion the pressure adequately. Not to mention how are you going to get them all exactly the same? Are you going to take them off to grind them? Good luck getting them off in one piece. Keep in mind that the stock stops are rubber. Mine had cracks in them and were 6 years younger than yours are.
I will take an hour or so and cost $21 in parts.
Old 03-29-2003, 02:34 PM
Bumpin' Yota's Avatar
with the sway bar disconnected I bet they give more than a "hair" of additional articulation.... I have yet to measure the difference due to my damn swaybar not letting the IFS fully articulate. But i have the low pro bump stops on mine right now....
Steve
Old 03-29-2003, 04:20 PM
well, took the swaybar out a long time ago... and thanks to cebby, i now understand why to get the new bumpstops... thanks for all your help.... now, does anyone know where to go, besides toyota, for a factory locker?
Old 03-29-2003, 04:27 PM
Firefyter-Emt's Avatar
I will hit it for the bumpstops too.. I am pretty suprised on how much more ir really does drop now with the bump stops changed.. You will gain about 1" of drop (without sway bars connceted) I bottom out the bump stop and I plan on the same with my sway bar discos..
Old 03-29-2003, 04:28 PM
Cebby's Avatar
Source
Try here
Old 03-29-2003, 04:35 PM
only an inch? ewwww, ill have to make my own, that are less than 11/16 lol
justdifferentials
Just Differentials
06-13-2022 07:40 PM
justdifferentials
09-05-2015 06:52 PM
Robinhood150
01-07-2006 06:12 PM
Sunday BBQ
05-27-2004 10:47 AM
Quick Reply: Bumpstops
