Bulb keeps getting burned-out - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-15-2007, 07:08 AM   #1 (permalink)
TEPUI's Avatar
During the last year, I've had to replace the bulb on one of my brake lights at least 5 times. One would assume there's a short-circuit somewhere but i really don't know how to diagnose it precisely. Is there an accurate way to diagnose this? I'd hate to take it to a shop where they do "trial & error", normally breaking something else that ends up being more expensive.
Is it possible that I'm using low quality bulbs? I would eventually like to switch to LEDs but I'd hate to keep burning them if the problem is actually a short-circuit.
has anyone experienced this before?
__________________
'00 トヨタ 4Runner VZN185
'97 トヨタ Land Cruiser Prado RZJ90 SOLD!
Get your トヨタ TOYOTA T-Shirts, Hats, Stickers here!
TEPUI is offline
Old 01-15-2007, 07:19 AM   #2 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
Is your housing cracked?
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 01-15-2007, 07:26 AM   #3 (permalink)
TEPUI's Avatar
Quote:
Negative.
__________________
TEPUI is offline
Old 01-15-2007, 07:42 AM   #4 (permalink)
gregbreakseverything's Avatar
Can you notice one brake light brighter than the other?
__________________
-Greg
Sold- 85 4wd toyota pickup. Stock and sweet!
'99 SR5 - Deckplate, ISR, Sweet stereo, all synthetic, KC day lighters, headlight wiring harness, Sonoran Steel #7, 285/75's.
gregbreakseverything is offline
Old 01-15-2007, 07:44 AM   #5 (permalink)
TEPUI's Avatar
Quote:
Not really...
__________________
TEPUI is offline
Old 01-15-2007, 09:22 AM   #6 (permalink)
TEPUI's Avatar
Somebody just told me that a short would have affected the fuse and not the bulb, seems accurate.
Could it really be that I'm using crappy bulbs?
__________________
TEPUI is offline
Old 01-15-2007, 09:26 AM   #7 (permalink)
Try a more expensive bulb? I usually use whatever they sell at canadian tire, nothing special. Also, try swapping the left and right bulbs, and see what burns out first. If you are a very gung ho type person, hook an ammeter up to each bulb, and see if they are pulling the same amount of current. Or the easier way of measuring the resistance of each bulb.
__________________
-Greg
Old 01-15-2007, 10:03 AM   #8 (permalink)
rdharper's Avatar
Short? No.
Higher voltage? Yes.. Check the voltage at the bulb with the brake light on. Probably not the problem as there is no way you could favor that bulb as opposed to the other unless there is a common line between the lights. If that were the case, and you had a poor connection on the other lamp, it would could be dim and the one in question is getting a higher voltage than expected. If the brake brightness the same for both sides, then that is not happening.. could also check the wiring diagram to verify.
Intermittent (poor contact)... possible. This would amount to a stress on the bulb. You should verfiy good contact inside the socket. Visual inspection for rust, loose connector. If in doubt measure ohms from lead input to inside the socket. Both ground and voltage in.
Poor quality... chances are zero to none.
Brake light is on for extended period... could cause early failure. Its meant for higher brightness for short periods. Stuck on would cause early failure.
Wrong bulb: Maybe.. but I assume you have the right bulb in that position.
So the first thing to look for is a poor connection, maybe rust related. Also, convince yourself the light doesn't come on for extended periods. Socket problems etc.
__________________
Richard
"Science by consensus... is not Science." Richard Harper -1988
'94 Toyota 4Runner V6 3L 158K miles 14mpg
'85 Toyota 22rec 4WD SR5 LB PU 208K miles 18mpg
'08 Honda Ridgeline RT 2.6K miles 16mpg
'06 Honda Rincon ATV 410miles/65hrs 22 mpg
rdharper is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Burned valve diagnosis alankenji_84 86-95 Trucks & 4Runners 14 01-22-2007 08:22 PM
Glove box bulb dead, changed bulb, checked fuse, still SOL Dug 95.5-2004 Tacomas & 96-2002 4Runners 6 11-06-2006 10:41 PM
Audio burned to DVD? jct61765 Computer Talk 6 07-18-2006 05:57 AM
College: Who is already getting burned out? SLC Punk Off Topic Talk 17 09-19-2003 05:38 PM
Large burned hole in spare? Babypig 95.5-2004 Tacomas & 96-2002 4Runners 2 05-23-2003 11:26 PM
2009 InternetBrands, Inc.
