building a new motor
Old 05-18-2004, 06:10 AM
awdrifter's Avatar
does anyone know if you need new head bolts for a 22RE when you are putting it back together? i checked arp website and they had nothing even listed for the 22RE... thanks for the help!
Old 05-18-2004, 07:43 AM
kyle_22r's Avatar
i'd definitely go with new ones. however, if you're not doing anything too major(race engine, high boost turbo) the ones from the dealer are perfectly fine
Old 05-18-2004, 08:35 AM
Head bolts definately need to be replaced, from what I understand once they are torqued once they are done. You could switch to head studs which are reuseable but it is not necesary, more of an upgrade. There is some good info on lc engineering's website on bolts vs. studs in the tech section.
Old 05-18-2004, 09:43 AM
awdrifter's Avatar
the motor is kinda insane so i am trying to do something good... thanks for the lc engineering reference!
Old 05-18-2004, 03:26 PM
Fahrenheit 451's Avatar
If the motor is "kinda insane", better go with the ARP studs. Bolts don't do all that well with a stock motor. Remember to torque the head using the specs for the studs and not the bolts. The studs are torqued a lot higher. You can trust me on this one
Old 05-20-2004, 06:58 AM
awdrifter's Avatar
thanks so much for the info... i called lc and got studs plus that fancy radiator and flex a lite fan
Flying91
45
04-11-2024 04:39 PM
cars-guy
08-16-2020 06:59 AM
okamikai
04-30-2018 10:19 PM
msane99
07-17-2015 10:13 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: building a new motor
