| New! Use your Facebook to securely log into this site, click logo to login |
| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Broken Wires In Steering Column
#2 (permalink) |
the clockspring cant be fixed so you have to buy a new one
#3 (permalink) |
yeah those wires on those ribbons looks pretty thin to work on. id rather go to a junkyard and get another one. usually, these things are at profuse amt.
when re-installing, turn the lil wheel and see maximum # of turn you can do and turn back half of it (w/ ur wheel centered), then put ur steering wheel back on.
__________________
o0 4Runner, Sequoia Wheels on 265/70/16, Airlift, Denso 4300K, 199mm Tundra Brakes |
#4 (permalink) | |
Quote:
#5 (permalink) |
Ok, is the clockspring the same thing as the spiral cable? It looks like the wires go into the spiral cable at the bottom of the backside, and they connect to the top of the frontside. If so, how do i remove the spiral cable assebmly. It seems like this is a touchy device, it centers the wheel. And also, how can you dissasebmle the housing on the clockspring, I like that idea.
#6 (permalink) |
the housing snaps together, you'll have to carefully press each clip in, to separate the assembly. At least Toyota has indicator marks on the outside of the housing, so it's simple to align after reassembly. I forget how many turns it was to center, fortunately you can shorten the cable to re-solder and still have plenty of travel..... There's a small plastic piece inside that most likely broke off, don't worry it'll work fine without it. Solder the wires and place a piece of electrical tape to cover the connections....
#7 (permalink) |
Sorry, I know that can be a pain the ass...
But, I couldnt help but start laughing... "I spun the wheel". That's something Id do for sure... :pat: Good luck to you!!
__________________
1996 4x4 3.4L SR5 4Runner 6" IFS lift * Front: Tundra TRD Coils/Bilstein 5125 * Rear: FJ80 Shocks/Coils * ARB Bull Bar + Warn M8000 * 35" MTR's * HID's * OBA * E-locked! |
#8 (permalink) |
Great, thanks BruceTS. I have it apart, and i see the cable. Im gonna try a pen solder gun. I feel like im working on an RC car with these wires, that or a computer cable...
"But, I couldnt help but start laughing... "I spun the wheel". That's something Id do for sure..." yeah, live and learn..... |
#9 (permalink) |
Hey thanks for all the replys everyone, I fixed it! The ribbon wire in the clockspring (spiral cable) was snapped at the connector with about an inch of wire left, so with some leet soldering skills from a buddy, we fixed it. Not to mention all the help from you guys. Thanks alot, saved me 300 dollars, and now i can help someone else.
James |
#10 (permalink) |
think this may be my prob...subscribe!
__________________
R.I.P. Princess Blackie 9.14.07 - 4.30.10 98 4runner sr5 33"s and locked with the usual suspects http://i130.photobucket.com/albums/p.../waterfall.jpg |
#11 (permalink) | ||
You realize you just subscribed to a nearly 4 year old thread right?
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Quote:
Quote:
#12 (permalink) |
Prime example of utilizing the search function....I dig it!
__________________
Weston 97 SR5: Profile 883/LC with OME/PC shocks ∙ 2" body lift ∙ ARB bull bar ∙ Safari Snorkel ∙ KC/IPF aux lighting ∙
315/75 BF Goodrich KM2s ∙ LC Wheels ∙ Vortex Cherrybomb ∙ Gobi Stealth System ∙ Toytec Lifts ∙ Gobi USA Racks ∙ Bushwacker |
#13 (permalink) |
yah....i searched...then subscribed so i can *remember* it later when i'm at home...
__________________
#14 (permalink) | |||
Quote:
BTW if you take one apart and resolder it would you mind taking some pics and sharing?
__________________
Quote:
#15 (permalink) |
yah, i could swing that!
__________________
| Tags |
| 2006, 97, airbag, buy, cable, cablewhere, clock, clockspring, connector, horn, spiral, spring, tacoma, toyota, tundra |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| steering column | GB4runner | 86-95 Trucks & 4Runners | 2 | 07-17-2007 01:47 PM |
| Steering column noise... | mtrdrms | 86-95 Trucks & 4Runners | 8 | 03-14-2006 01:45 PM |
| Steering Column/Steering wheel moves/wiggles left and right??? | grimpy | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 11-17-2005 10:17 PM |
| broken wires in steering column | 4x4taco | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 08-31-2005 01:13 PM |
| steering column ? | Mytyota | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 06-15-2003 10:04 AM |
