broken bolts help
Old 03-05-2011, 10:00 AM
warpigg's Avatar
Exclamation broken bolts help
i broke three or four of the bolts that hold on my skidplate so we cut that off and now i want a skidplate to go whellin. so do you guys have any nifty tricks to take broken bolts out other then drilling and tapping, and lube vice grips and a torch?
Old 03-05-2011, 10:02 AM
jbtvt's Avatar
Heat the frame around it, hit the bolt with PB blaster to cool/shrink it, and use an EZ out.
Old 03-05-2011, 10:07 AM
warpigg's Avatar
do you think home depot might have an EZ out?
Old 03-05-2011, 10:17 AM
jbtvt's Avatar
Don't think they do. You say you're in Rutland area? I know Noble Ace sell them.
Old 03-05-2011, 10:20 AM
warpigg's Avatar
dont want to feel dumb but where is that in rutland, i actually live near poultney.
Old 03-05-2011, 10:27 AM
jbtvt's Avatar
http://maps.google.com/maps?um=1&ie=...ed=0CBgQnwIwAA
There's probably a place that sells them closer to you though in Poultney. They're pretty common, call around. Good one are made by Irwin, in the drill bit section.
Old 03-17-2011, 05:02 PM
halo32c's Avatar
Talking broken bolt
Try a reverse drill bit from sears. I used this to take off a broken cam shaft bolt.
Old 03-17-2011, 05:33 PM
shepherd2111's Avatar
Yes, a left hand drill does work from time to time. Just make sure its the right pilot drill for your easy out in case it doesn't move it, your hole is still the right size
Old 03-17-2011, 05:40 PM
halo32c's Avatar
True enough. Also use a center punch if possible.
JNapolitano
11-14-2019 07:46 PM
ToyoToler
08-08-2015 08:43 AM
gmonnie123
07-26-2015 02:44 PM
jon.r
07-11-2015 03:34 PM
Snort
07-09-2015 03:58 PM
Quick Reply: broken bolts help
