Break Line Leak? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-11-2004, 10:27 AM   #1 (permalink)
AKennedy87's Avatar
Send a message via AIM to AKennedy87
Break Line Leak?
So the other day I took a 80 mile trip through the western Massacusetts hills to school and parked my truck in my driveway. No problems. My brother goes to the store this morning, 2 days later and the breaks don't work. He pulls in and I see that fluid is spitting out near the gas tank, right side on 87.
I go check it out and there is a leak from where the soft hose meets the 2 metal steel lines. How is this fixed? If the thing that joins them is cracked is that easy to replace? Anyone ever had this problem before? I'll probably be working it next weekend (Oct 16) so if i could figure out how to do it and what parts to get before than it would be sick.
Thanks A Lot...Go Red Sox!!!!!
Alex
__________________
1987 4Runner SR5 4x4 - 5spd M/T 22RE - 3" Add-A-Leaf Rear - 31/10.5/15 Michelin LTX A/T's on 98 Tacoma Wheels - Aisin Manual Hubs - Thule Rack System - 12" JL W0 w/ Alpine amp and custom box - JVC headunit
Cardomain
AKennedy87 is offline
Old 10-11-2004, 11:29 AM   #2 (permalink)
bike4miles's Avatar
Send a message via Yahoo to bike4miles
Is the hose cracked or is it the splitter? I would sugest spraying all fittings with liquid wrench or WD right now and reapeat several times before you dive into it or you are almost certain to strip out thoes 8mm fittings (the other guys are sure to back me on that one). As long as you can get the stuff appart, it should be an easy fix, although bleeding the breaks after you are done can be very time consuming.
__________________
--Miles
Sold
'91 4runner, 22re, 5 spd manual, 180,000 miles,
cone filter, Downey 1.5"HD coils, SkyJacker Nitrogens, Magnaflow Exhaust, Stull grill, Clears all around. Check out my sound proofing project and other mods:
My 4runner page
My 2006 Camry page
I'm a Myspace Addict!
bike4miles is offline
Old 10-11-2004, 11:45 AM   #3 (permalink)
Staff
Yoda's Avatar
Very unlikely the fitting broke (but not impossible). Usually rust out or vibration crack on the tubing.
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 10-11-2004, 12:06 PM   #4 (permalink)
AKennedy87's Avatar
I checked again and there are 2 steel tubes that run along the whole side and dont split at all I don't think. I dont know if they are 1 or many pieces but I believe they are just 1. It looks somewhat of an easy fix except for the fact that they run under the gas tank and don't screw in until the front breaks split with them.
I agree that the 8mm bolts will be troublesome but I think the clamps that hold down the tubes along the frame may be worse. When I tried to loosten mine for the front sway bar they cracked right off. Anyone have advise on this?
I am pretty sure on it just being the tubing cracked so does anyone know the parts numbers to those tubes? If I do one I will do both.
Thanks,
Alex
__________________
Cardomain
Old 10-11-2004, 01:40 PM   #5 (permalink)
Staff
Yoda's Avatar
They aren't the ones that screw into the level sensing valve, are they? Sure its not the valve or hose?
Make sure you know what is leaking before spending the bux.
__________________
David
TLCA 14788
Yoda is offline
Tags
beak, break, champions, cost, cruiser, effects, fix, fluid, heater, land, leak, leaking, leaks, line, lines, online, pressure, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
kayline kay line k line soft top 4runner used TN $250 kwikrnu The Classifieds GraveYard 18 07-02-2007 05:54 PM
Vacuum line leak?? celica860 86-95 Trucks & 4Runners 2 05-11-2007 05:56 AM
Brake Line Leak Veladarius 86-95 Trucks & 4Runners 14 08-13-2006 05:36 AM
Leak in rear heater line--part #? Vermonster 95.5-2004 Tacomas & 96-2002 4Runners 9 01-03-2006 01:58 PM
fuel line leak cause hard starts? hale 95.5-2004 Tacomas & 96-2002 4Runners 5 12-03-2004 07:52 AM
2009 InternetBrands, Inc.
