brakes vibration
Old 04-06-2004, 12:33 PM
dirk diggler's Avatar
brakes vibration
hey guys, got my brakes done about a year ago, all was good until a few months back, when i step on the brakes, i get a lot of vibration feedback in the steering wheel, wondering what it is, rotors, loose pads? anyway, i'm still getting a lot of brake dust, hmm... any suggestions? thanks, dd
Old 04-06-2004, 12:41 PM
runner02's Avatar
My 4Runner and Taco both did that. In both cases it was the rotors.
Old 04-06-2004, 01:52 PM
MTL_4runner's Avatar
It's almost always rotors causing that symptom.
Old 04-06-2004, 02:02 PM
DavidA's Avatar
Yep, sounds like you got some chewed up rotors. I have had that on older trucks.
Old 04-06-2004, 02:06 PM
Luke Groundrunner's Avatar
its ur rotors, and here's why... (someone correct me if i'm wrong) the rotors got overheated at one time (maybe u slammed on the brakes too much?) and now the rotors are warped and when the pads hit the rotors they skip. and as time goes on the skipping and the vibrations are going to get worse. you can probably just get your rotors resurfaced and that would fix it. someone told me that the rotors on my '90 are really thin and they most likley couldn't be resurfaced and i just needed to get new ones, but since you have a '97 you should be fine.
Old 04-13-2004, 10:14 AM
Slow Boy's Avatar
When you have your rotors turned, request that they grind from both sides. It saves a bit of material instead of having them ground completely on one side.
Old 04-13-2004, 10:20 AM
WT
WT's Avatar
I say do a search there is alot of info here about brakes and warped rotors.
In short rotors are more than likely warped and you should just replace them and put on new pads, IMHO. I did this over a year ago and have not had a problems since. Also adjust your rear brakes to be sure there doing some of the work.
Old 04-13-2004, 11:36 AM
JSharp's Avatar
I'd drive it a while and see if it clears up before you spring for pads and rotors. Mine started the common vibrations over a year ago but when I checked the pads they weren't even 1/2 gone. It seemed silly to replace all that stuff at less than 50K miles and with only 1/2 pad wear so I left it. It's now much smoother than it was then so I'll wait until the pads are nearly worn out before I bother to fix it...
Old 04-13-2004, 01:18 PM
I haven't had luck with turning them, once they warp they are pretty much toast. I have had them turned but use the brakes hard at all and they'll warp even faster. I find that if they have warped at all, either just ignore it and see if it fixes itself or replace it all. Don't waste your money to turn em.
Old 04-14-2004, 07:20 AM
DrummerDaveB's Avatar
You can get brand new Brembo rotors for it at taylorautomotive.com for about $42 each shipping included.
You might as well replace them and not bother turning them. Turning them will cost you like $10 each, if you take them the rotors. Plus, you still have to worry about them warping again soon.
tinigunner11
08-14-2015 01:19 PM
lectric80
08-11-2015 12:02 AM
CanRunner
07-20-2015 01:29 PM
Quick Reply: brakes vibration
