Brakes on 3rd gen
Old 02-17-2005, 03:21 AM
dibble9012's Avatar
Brakes on 3rd gen
Hey, I think i need my pads replaced, but im not sure. Whenever I stop, it feels like it is braking with ABS, but I know its not(no ABS light, you cant feel it in the pedal.) I washed the brakes off thinking it was mud or something, but it still does it. I know that when I bought the truck, they said that the brake pads might need to be replaced soon. Thanks for any help!
Old 02-17-2005, 04:07 AM
dibble9012's Avatar
just wanted to bump this, and add that its on the front drivers side only, (i think) this wheel was also squealing a lot, had some mud in there, washed it out the best i could though
Old 02-17-2005, 04:42 AM
FilthyRich's Avatar
https://www.yotatech.com/forums/show...=brembo+rotors
AND
Either way should have you stopping on a dime
Old 02-17-2005, 04:45 AM
rimpainter.com's Avatar
Rotors are shot. I am running Autozone 1-year warranty rotors with PF pads for about 4 months now. No problems. $165 shipped to your door.
Old 02-17-2005, 04:48 AM
dibble9012's Avatar
anyone know what exactly would cause this, are they just old, or what?
Old 02-17-2005, 04:50 AM
FilthyRich's Avatar
yep, stuff wears out. I have been running the non slotted BBrembo rotors w/ over the counter pads w/ NO problems. The brembo rotors are GREAT and cheap
Old 02-17-2005, 05:00 AM
dibble9012's Avatar
ok, thanks, ill probably try to get aftermarket brembos, ive read good things about them, and bad things about stock rotors. Anyone have rust problems on the brembos? Its weird though, this literally happened overnight, one day fine, the other day bad. I live in a new subdivision, and they flooded the road when they cleaned it, maybe the rapid cooling warped them?
Old 02-17-2005, 05:03 AM
MTL_4runner's Avatar
Could be brake glazing or pad chatter. You can either replace them (if the are due....look at how much pad is left) or if they still look good, you should remove the rotors and give them a rough sanding with 220 to break the glazing if there is any (make sure you sand in a circular pattern....ie non-directional). I am assuming also that the rotors are not warped since you mention it feels like ABS kicking in....very tough to know exactly what you mean by that. If they are warped, they should be replaced. Anyway, there are some ideas.
Old 02-17-2005, 05:06 AM
dibble9012's Avatar
thanks for your help, im gonna take it in to get checked up on, oil change is needed soon anyways
Old 02-17-2005, 05:21 AM
dibble9012's Avatar
I dont think i want slotted rotors, mud and rocks could get stuck in there
Old 02-17-2005, 05:44 AM
Since you don't want slotted...
Check out the Autozone internet "package." As I mentioned, about $165 shipped for 1-year warrantied rotors and PF pads. Easy to install yourself and you can return the rotors to any Autozone if they warp within 1-year.
My brakes have been great ever since.
Old 02-17-2005, 06:00 AM
dibble9012's Avatar
hmm, went to autozones website, cant find the package, but i can find duralast rotors and morse ceramic pads, they look ok
Old 02-17-2005, 06:05 AM
https://www.yotatech.com/forums/show...utozone+warped
Towards the end is the part # for the pads
Old 02-17-2005, 08:50 AM
dibble9012's Avatar
I will get them installed by a mechanic I know. I have no clue how to install rotors or pads, I would like to learn, but not the hard way driving down the road with failed brakes
Old 02-17-2005, 09:27 AM
Cardesign's Avatar
just ordered the brembos myself and going to autozone to pick up the PF pads.
Old 02-17-2005, 12:49 PM
dibble9012's Avatar
ok, well i just got back from school, decided to take a look at it myself since its not freezing outside. I jacked the truck up, and turned the wheel by hand, it sounds like a rock or something is stuck in there. You can also see a little deeper grooves in the rotor. I tried getting it with the hose, but that doesnt help. Is there any way I can widen the gap between the rotors and pads, just to see if I can get the stuff loose? Maybe the rock is behind the shield on the other side? Any help would be great before I take it in to the mechanic.
Old 02-17-2005, 01:00 PM
The only way to widen the gap is to remove the part of the caliper that is holding in the pads.
It is REALLY simple if you have a ratchet and a 14mm socket. But if you don't feel comfortable, then don't do it.
If the rotor is scored, you are most likely going to need a new one anyway (depending on the thickness spec).
Old 02-17-2005, 01:02 PM
Bennito's Avatar
. I tried getting it with the hose, but that doesnt help. Is there any way I can widen the gap between the rotors and pads, just to see if I can get the stuff loose?.
Since you got it this far...lower it back down, break loose your lug nuts, jack it up, take the nuts n wheel off. Get your allen wrench set out and remove the two bolts holding the caliper on. You should have enough play to take the caliper off the rotor without removing the brake line (if your rotor is worn down, you may need to "persuade" the caliper past the lip at the very edge of the rotor).
Now you can eyeball the pads very easily.
If this is your first time, dont' worry. Its easy (in fact your rotor will pull off now). To put it back together simple put the caliper back over the rotor and reinstall the two allen-bolts. Put the wheel on, do your lug nuts and call it a day.
Old 02-17-2005, 01:04 PM
Bennito's Avatar
Uh-oh. I coulda swore it was a allen bolt to pull the caliper...maybe that was my old Wagoneer. I'm the online bum giving bad advice.
Dibble - Either way the morale of the story is that it is easy to inspect.
Old 02-17-2005, 01:11 PM
Older Chevy's use allen bolts too.
Quick Reply: Brakes on 3rd gen
