YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 12-20-2003, 02:15 PM   #1 (permalink)
Maverick's Avatar
Brake upgrade for 92 4x4 Truck
I have a 1992 4x4 with 33x12.5's and a 3inch body lift. I'd like to upgrade the brakes maybe increase the front rotor size, and go with a drilled and slotted rotor, maybe go with a braded steel brake lines in the front, also, I'd like to upgrade the calipers. I'd even like to convert the rear drums to disk brakes but haven't been able to find a kit. Does anyone have any suggestions for me? Thanks in advance
M
Maverick is offline
Sponsored Links
To remove this ad, register today!
Old 12-20-2003, 02:32 PM   #2 (permalink)
You can use LC parts to do a rear disc swap (why bother? 90% of stopping is done with the fronts....) I thikn there is a writeup on 4x4wire.com. I don't believe there are any brake upgrades other than SS lines and x-drilled/slotted rotors. The brakes are already pretty big (supra guys looked at upgrading to ours) and stop pretty well...I'd go with just xdrilled/slotted + SS lines, I don't believe there are any off the shelf upgrades other than those, and you DON'T want a cobbled-together brake system (or maybe you do? )
__________________
New York City, NYC, pretty mean when it wants to be, black leather, knee hole pants, can't play no highschool dance, fuzz tone, hear 'em go, hear 'em on the radio - R A M O N E S, Ramones
OLD: '90 4Runner SR5 auto v6 150k
NEW: '85 long bed xtra cab 5spd 22R 200k
NEW NEW: '89 Ford Taurus SHO, 137k Miles, 650 miles after I got it : water pump takes a shizzle, now I'm knee deep in a front maintainence from hell. Even broken it's faster than the 4Runner
Los Gatos? is offline
Old 12-20-2003, 02:40 PM   #3 (permalink)
Maverick's Avatar
so what about putting some different calipers on as well? So you're saying just upgrade the rotors and lines in the front, and that will be substancial improvement from stock, and just leave the drums in the rear alone?
Maverick is offline
Old 12-20-2003, 03:25 PM   #4 (permalink)
partszar's Avatar
brake upgrade
Try finding a master cyl for the v6 trucks. I believe it has a larger diameter 1 inch I think. this will increase the pressure applied to the brakes. Also check the LSPV at the rear brakes to make sure it is adjusted properly.
__________________
Paul
"We sleep soundly in our beds because rough men stand ready in the night to vist violence on those who would do us harm"
85 SR5
EFI
M/T
4wd
custom 2.25in exhaust
rear true-trac diff
31x10.5x15 winston M/T on 15x7 alloys
Front Range Off-Road Severe use front frame brace
Front Range Off-Road front bumper
OME suspension INSTALLED!!
NWOR greasable spring shackles
custom rear bumper w/spare tire carrier
Warn 8000 winch
TRD Level 1 cam
partszar is offline
Old 12-21-2003, 05:13 PM   #5 (permalink)
Maverick's Avatar
Thanks a lot I'll check it out
M
Maverick is offline
Old 12-21-2003, 06:23 PM   #6 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
Front Range has a full floater kit that allows use of disks in back.
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 12-21-2003, 06:43 PM   #7 (permalink)
martin's Avatar
I understand that with most of the rear brake kits I have seen you lose the use of your parking....No thanks.
Martin
__________________
88 4Runner
05 Sequoia
02 Tacoma
martin is offline
Old 12-21-2003, 07:00 PM   #8 (permalink)
Cebby's Avatar
Quote:
Martin
The FROR kit uses Supra calipers that include a parking brake.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 12-21-2003, 07:10 PM   #9 (permalink)
martin's Avatar
I have looked at that one before, but it is a fairly expensive kit that requires you to float.
Martin
__________________
88 4Runner
05 Sequoia
02 Tacoma
martin is offline
Old 12-22-2003, 02:25 PM   #10 (permalink)
Maverick's Avatar
When you say float what exactly are you refering to?
And where would I go to purchase such a brake kit, and around how much would I be spending? Thanks in advance
M
Maverick is offline
Old 12-22-2003, 04:19 PM   #11 (permalink)
martin's Avatar
http://www.frontrangeoffroadfab.com/floater.htm
Martin
__________________
88 4Runner
05 Sequoia
02 Tacoma
martin is offline
Old 12-22-2003, 04:42 PM   #12 (permalink)
kyle_22r's Avatar
rear discs are actually quite helpful. the spread between front and rear weight shift on most cars is somewhere around 70/30
with disc brakes in the rear, you don't get them destroyed with mud and other gunk like with drums, plus they're much easier to work on
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 12-22-2003, 10:33 PM   #13 (permalink)
FROR makes a NON floating rear kit as well, which I would assume is cheaper (didn't look) and probably what you want. Floating rear just means you could turn off rwd to tow it or to drive in fwd without removing driveshaft or fuxxoring something up bad hehe
Also FROR seems to think an FJ88 bolts up and is an improvement over 4Runner cylinders....
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Brake Upgrade Options? halcyon0 86-95 Trucks & 4Runners 0 06-15-2007 12:14 PM
Tundra Brake Upgrade... bamachem 95.5-2004 Tacomas & 96-2002 4Runners 102 03-16-2007 04:21 PM
Brake upgrade 2wheelBLACKOUT 95.5-2004 Tacomas & 96-2002 4Runners 4 01-25-2006 04:34 PM
92 Toyota 4x4 pickup ABS brake light issue and TBI question 99SC4Runner 95.5-2004 Tacomas & 96-2002 4Runners 0 08-13-2005 06:37 PM
brake upgrade for 2wd desert whomper 95.5-2004 Tacomas & 96-2002 4Runners 3 04-05-2005 11:34 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
