Brake swap
what if i made a whole new spindle? if i could mount them could i get them to fit? also would hte bolt pattern be the same and if not could i take it to a machine shop to have it redone?
well, the tundra uses a non serviceable type wheel bearing and the rotor slides over the wheel studs, while the 95 and older trucks use a rotor which is bolted to the back side of the hub, the only way to tell would be to get both trucks side by side and start comparing things, BTW, tacos and 3rd gen runners use the same type of brake setup as the tundras, except that the rotors are smaller on the tacos and 15" wheel runners
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
Johntom240
7
07-13-2015 12:18 AM
