YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-10-2008, 11:33 PM   #1 (permalink)
Brake rubbing
I recently bought a 99 prerunner that had been in storage for a year, when i got it there was a bad vibration in the brakes, especially at high speeds. I figured it was from rust and what not. The front pads needed to be replaced soon so i figured id just do that and do my rotors at the same time to get rid of the the vibration. Now that ive done this the vibration has gotten ALOT better but when i use my brakes i can still feel a very light vibration, you can hardly notice it but it is there...should I worry about it? I can really only feel it when my foot is resting on the pedal right before i push it... I noticed when I have the front end in the air and I spin the tire you can hear what sounds like the rotor rubbing, its not enough to stop the wheel from spinning but there is a very light rubbing, is this normal with new rotors? I imagine this is the vibration I feel. Bad?
Sk37ch is offline
Sponsored Links
To remove this ad, register today!
Old 05-11-2008, 03:15 PM   #2 (permalink)
Cxrazy's Avatar
There is always a slight rubbing. The weight of the tire makes it not matter when the car is on the ground.
Check to see if your tie-rod ends/ball bearing joints are loose.
__________________
-Logan
Quote:
Originally Posted by Sold
1998 4Runner Limited - Anthracite Metallic - 265/75/16 Radial APR's - Cupholder Mod - Removed Pinstripe
2004 Tacoma - Xtra Cab - TRD - Rear Locker - 5 Speed
Cxrazy is offline
Old 05-11-2008, 03:35 PM   #3 (permalink)
Front right tie rod end is a little lose, thanks for the input
Sk37ch is offline
Old 05-11-2008, 05:49 PM   #4 (permalink)
Cxrazy's Avatar
Glad I could help!
Hope that fixes your problem.
__________________
-Logan
Cxrazy is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
rubbing ken914runner 86-95 Trucks & 4Runners 14 02-06-2007 04:03 PM
A little rubbing dantheman387200 86-95 Trucks & 4Runners 16 11-05-2006 10:11 AM
Tires rubbing need help!!!! yoda92 03+ 4Runner/GX470, & 05+ Tacomas 7 12-27-2005 02:48 PM
rubbing but where? TBob 95.5-2004 Tacomas & 96-2002 4Runners 7 02-22-2005 12:33 PM
Why are they rubbing? Gangus2006 95.5-2004 Tacomas & 96-2002 4Runners 14 11-16-2004 05:16 AM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
