brake pedal clunk
Old 08-03-2010, 09:00 AM
Billinsd's Avatar
brake pedal clunk
My 2002, taco,4x4,double cab brake pedal chunks when I bear down on it right before it stops ? It's not the driveshaft, It's lube and I feel the clunk on the brake pedal. It feels like the tires are pushing back into the wheel wells. Is this possible? I run 265x75s. It's probably the rotors, but it feels different? Thanks.
Bill
Old 08-05-2010, 12:25 PM
Ritzy4Runner's Avatar
If the sound seems to be coming from the rear, you may have a leaking axle inner seal. If the seal leaks gear oil into the drum, it soaks into the pads and causes them to "stick" to the drum when you apply the brakes. Just before you stop, it will make a "clunk" noise. I had this happen when my rear inner seal went. You will need to check your rear brake shoes, just jack the truck up, pull the wheel and drum and see if you have black looking "grease" inside the drum. Good luck
Old 08-05-2010, 07:47 PM
Billinsd's Avatar
Thanks, no there is no sound, I feel it on the brake pedal. I feel it when I brake hard and when the brake pedal is almost fully depressed. It feels like something is binding, or there is a rock under the pedal. And I feel it in the front of the truck.
I know what warped rotors feel like and this is not the same thing, unless they are are really, really warped bad? Or it's the calipers?
Thanks
Bill
Old 08-06-2010, 07:53 PM
Billinsd's Avatar
I seem to notice it when I'm 4 wheeling and/or have a really load?
Thanks
Bill
Old 08-06-2010, 08:10 PM
kball's Avatar
sticking caliper? Maybe when you really bear down on the brakes it finally lets loose??
Old 08-09-2010, 07:05 AM
Billinsd's Avatar
Seems to happen when the truck is REALLY loaded down also?
Thanks
Bill
Old 08-09-2010, 12:11 PM
tunnelmotor99's Avatar
My 97 made a similar noise when I was pulling a small 4x6 trailer. When I applied the brakes, I would get a very brief rubbing/vibrating noise that vibrated the pedal and the floor. After I dropped off the trailer, the noise went away...
Old 08-18-2010, 03:49 PM
Billinsd's Avatar
Ha, It's the abs pulsating back when I'm on uneven ground
fountain
12-31-2015 06:08 AM
ty1er
08-01-2015 11:53 PM
PopsDad1
07-30-2015 02:21 PM
ripp96
07-25-2015 02:32 PM
Quick Reply: brake pedal clunk
