Brake Light on after bleeding
Old 02-18-2010, 05:26 PM
ryani's Avatar
I just finished bleeding my brakes and went to start the runner and the brake light on the dash stays on. I disconnected the battery and tried it again with no luck. The level is full after I got clear fluid from all four brakes.
Has anybody else ran into this? Any advice would be appreciated.
Thanks
Old 02-18-2010, 05:39 PM
mastacox's Avatar
My guess- your brake fluid is still a bit low. Fill it up to the brim.
Old 02-18-2010, 05:45 PM
Truckfiend's Avatar
X2 and make sure the float moves freely.
Old 02-18-2010, 05:46 PM
ryani's Avatar
It's up to the max line. I went out and drove it and all seems well. I suppose another bleeding is in order. The e-brake is ok. Just running out of ideas
Old 02-18-2010, 05:47 PM
ryani's Avatar
The float?? wasn't aware of that. What's it look like. Is it that screen in the rear chamber
Old 02-18-2010, 05:52 PM
mastacox's Avatar
I'm tellin' ya, fill it up a little more just to be sure before you rack your brain any more. It's the easiest thing you can try first.
Old 02-18-2010, 05:53 PM
mastacox's Avatar
It's on the bottom of the brake fluid reservoir cap.
Old 02-18-2010, 06:01 PM
ryani's Avatar
GOT IT!!!!! It was up to the max line but I filled it up even more, started it up and pumped the brakes and off it went. Thank goodness. I can sleep tonight. Thanks brian for the advice.
Old 02-18-2010, 07:00 PM
mastacox's Avatar
Triumph!
ashersullivan88yota
01-18-2022 05:37 PM
fountain
12-31-2015 06:08 AM
09-04-2015 09:27 AM
Sandman
07-14-2015 12:36 PM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: Brake Light on after bleeding
