Brake Issue
Old 03-28-2005, 08:52 PM
L33T35T 4Runner's Avatar
Brake Issue
if i brake kinda hard, my brake pedal goes down about 75% and gets firm, then it kicks back up about 15-25% and brakes harder. no matter what, the brakes dont work like they should. it feels like the brakes finally "wake up" or something.
also, my rotors are warped. how hard is it to replace those? do i have to repack the bearings?
thanks
Old 03-28-2005, 10:46 PM
jimbo74's Avatar
you need to repack or replace the bearings and the grease seal if you are planning on replacing your rotors... not too sure on exactly waht it sounds like is happening, but it somewhat sounds like abs
Old 03-28-2005, 11:09 PM
Brendan's Avatar
depending on how badly the rotors are warped, you could just take them in to be machined. definitely cheaper than buying new ones
Old 03-29-2005, 06:24 AM
ive thought about getting them machined, but they've been warped for so long i doubt they're still machinable. plus those brembo rotors are sexy
anybody know about what my problem sounds like?
Old 03-29-2005, 10:43 AM
Brendan's Avatar
master cylinder is on it's way out maybe??
Old 03-29-2005, 11:31 AM
Robinhood150's Avatar
My brakes have been doing that too, lately. Seems to do it more in hot weather. I have no idea what it is, but I figured it had to do with the MC. It seems fine so far...let me know if your brakes go out and you hit somebody...I'll change mine then...
If your 2wd hub is the same as my 4wd, you'll need the huge 54mm socket.
Are you back from the desert?
Old 03-29-2005, 04:48 PM
yup
hmm... im still curious about this brake problem. im getting new shoes by the way, 31x10.5r15 bf goodrich all terrain T/A KO. 113.27 + tax + 11.75/tire for install. 535.19 out the door
Old 03-29-2005, 05:19 PM
It's amazing how much a 2" increase in diameter makes. I'm pricing 33x10.5 BFG muds and it seems everywhere is about $165 each.
Old 03-29-2005, 05:23 PM
158.78 at sams club
http://search.samsclub.com/eclub/sea...chfor=33125015
Old 03-29-2005, 10:49 PM
bump up
jasonty
41
12-23-2018 01:00 PM
fountain
12-31-2015 06:08 AM
CanRunner
07-20-2015 01:29 PM
Johntom240
7
07-13-2015 12:18 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Brake Issue
