Brake help!!!!!!
Old 08-22-2005, 08:24 AM
Brake help!!!!!!
I have an 88 4Runner and out of the blue yesterday the brake pedal starts to drop if I maintain pressure on it. It stops great initially but if I'm on a hill or just hold the brake it will drop all the way to the floor within about 30 seconds if I don't pump it. There is no leak anywhere.........!?!?!? Any ideas?? Thanks for your time.....................TIM
Old 08-22-2005, 08:40 AM
eric-the-red's Avatar
The seals are going, probably in the master cylinder. It doesn't leak, just the fluid gets past the seals and you loose pressure. Replace or rebuild the master.
On an 88 if the slave is original you might want to replace that too while you're there.
1uzRunner
63
11-10-2018 03:58 PM
old87yota
09-09-2015 12:39 PM
fabing455
09-07-2015 08:08 AM
Scatterbrain
09-03-2015 06:46 PM
Quick Reply: Brake help!!!!!!
