Brake brand for rotors/pads recommendation?
Old 03-20-2004, 11:15 AM
kenfused's Avatar
Gonna change my rotors, and pads soon.
Any recommendations?
Nothing too fancy...
Was going to go to Kragen or Pep Boys,
but didn't know what brand or Type was
reputable.
Thanks!
Old 03-20-2004, 12:49 PM
cruizin01's Avatar
Try a search, the same topic was covered not two weeks ago.
Old 03-20-2004, 02:04 PM
KZN185W's Avatar
reputable.
Thanks!
Check out Disc Brake Australia (DBA) and Brembo. these are one of the best!
Just don't know which one of the two is better.
When I get my sluggish brakes fixed, I'll go for a pair of DBA slotted rotors.
Old 03-20-2004, 10:49 PM
kenfused's Avatar
Hmmm. others seemed to mention Performance Friction by Autozone, but when I called them they said they didn't have any for the 4Runner...
Should I go with toyota made Rotors and pads?
Old 03-20-2004, 11:23 PM
keisur's Avatar
Toyota. they are quality. the lifetimers you get from the auto parts places are junk, thin junk and the pads and shoes separate from the frames. stick with oem brake parts if you want quality and longevity.
Old 03-21-2004, 12:36 AM
KZN185W's Avatar
Am not sure if Toyota has the slotted rotors. Slots do improve performance by removing dust and water caught between the pads and rotor. It also keeps your pads from becoming glazed. But pads do last longer when using oem rotors.
Cross-drilled ones are not recommended for heavily-laden light trucks.
HTH.
Old 03-21-2004, 07:00 AM
keisur's Avatar
yea, Toyota doesn't have slotted or cross-drilled. I also agree that things last longer, as well as fit better when left oem. there are a few here that have aftermarket brake stuff like slotted rotors and I hope they chime in soon. OEM pads are about twice as thick as the cheap lifetimers from autozone or those places. your gonna pay 30+ for oem pads but they are going to brake better and last longer.
Old 03-21-2004, 07:48 AM
humanoid's Avatar
reputable.
Thanks!
Go with Brembo. So far the cheapest I've seen is on this website. I've heard that OEM rotors have a tendency to warp over time so I would go with aftermarket rotors, that's what I'll do my next brake job.
As for pads, well, OEM seems the way to go. Hope this helps.
Old 03-21-2004, 10:14 AM
Mulkey's Avatar
I believe Performance Friction make the TRD pads and the same pads are at Autozone but they have them listed as Land Cruiser pads. I am pretty sure there has to be pads/rotors that are better than OEM b/c my brakes have been soft and sucked from Day 1. It is time for a change soon.
Zpd426
01-02-2016 01:15 PM
bighaydn
08-04-2015 07:17 PM
TJWilly
07-31-2015 02:05 PM
terminator
07-27-2015 07:13 PM
CanRunner
07-20-2015 01:29 PM
Quick Reply: Brake brand for rotors/pads recommendation?
