Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
3.4 Supercharger Boost Gauge Install
#2 (permalink) |
Personal
Sales Rating: (0)
[OP]
Here is a video, maybe it will be a little more clear exactly which line he used:
http://s101.beta.photobucket.com/use...7b2de.mp4.html |
#3 (permalink) |
Personal
Sales Rating: (0)
as long as the hose is hooked into the intake manifold in a spot that is unaffected by the throttle position it should be fine. You could try changing the vac tube location to another point and see if that changes your numbers.
Engine vacuum is counted in inches of mercury, not psi. Boost is calculated in psi. Pulling 17 inches at idle sounds about right as does 10 inches while cruising. Hopefully someone with the same setup can chime in. Changing the thread title (if possible) to something with "3.4 supercharger" in it will bring in the people you need.
__________________
It's not turbo lag...its foreplay ~~~~~~~~ 85 pickup, fancy paint job, 7mgte swap, 6" Marlin Crawler lift, 35x12.5 MT baha MTZ for street 36x12.5 swampers for fun, 5.29, ARB locked front and rear, no crack dash :) enough gauges to make a helicopter pilot jealous, numerous other doo dads and I still get 25mpg and can race mustangs on the highway. Build up thread: http://www.yotatech.com/f198/nothing...pickup-250752/ |
#4 (permalink) | ||
totally a bro
Personal
Sales Rating: (2)
Staff
sounds like you either have boost leak, or the boost gauge leaks.
__________________
92 toyota truck sc'd 3.4, URD 7th injector kit, 2.1 URD pulley, 5spd, 4.30 gears, E locker rear, magna flow cat and muffler, 2 1/2 pipe, isr mod, 1" BL, trail gear sliders, 1.5 bjs front, sway away torsion bars, add a leafs and 2inch lift shackles rear, rancho 5000 265/75/r16 nitto terra grapplers, xrc8 winch in front bumper, rhino lined bed. RB4R- SAQuote:
Quote:
TREADLIGHTLY Possibly end your existance for a dollar? |
#5 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
The truck has 182,xxx miles on it, I only bought it a couple months ago so I am not sure when the supercharger was installed so I should probably just go ahead and replace the nose drive, but dang the kit is $550! |
#6 (permalink) |
Personal
Sales Rating: (0)
Hey now slow down a bit!!!!
might verify everything possible before you start talking rebuild kits, let the answers come in and see what is figured out!! I highly doubt the charger was installed off the factory line so I wouldn't imagine it has that many miles on it. Do you have any ties with the PO to fine out some history??
#7 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
Unfortunately, I do not know the previous owner, I bought it through a dealership (Kuni Lexus) |
#8 (permalink) |
Personal
Sales Rating: (0)
Oh dang didn't even notice the location
Hmm wonder if there is a way to test the gauge to see if its functional? You got a mechanic you can go to? I would imagine you could test it with another testing gauge to compare the readings??
#9 (permalink) |
Personal
Sales Rating: (0)
[OP]
That is probably what I am going to have to do, but just don't want to have to drop more cash if it turns out the shop simply installed it improperly.
#10 (permalink) | ||
totally a bro
Personal
Sales Rating: (2)
Staff
reading vacuum is small negative pressure. But if its got a poor connection under boost it could be leaking. However these first gen sc units were prone to leaks around the idle bypass valve.
__________________
#11 (permalink) | ||
totally a bro
Personal
Sales Rating: (2)
Staff
where does the line run to? it doesn't show in the picture and I have a black second gen sc.
__________________
#12 (permalink) |
Personal
Sales Rating: (0)
[OP]
I'm not sure exactly where it goes, the video in my second post kind of shows the line a bit better.
#13 (permalink) | ||
totally a bro
Personal
Sales Rating: (2)
Staff
Looked at the video, the source is okay. What else is pigtailed into that line? do you have any fuel mods on the rig?
__________________
#14 (permalink) |
Personal
Sales Rating: (0)
i have the black s/c and it has an allen head set screw type of deal on the back on the s/c.. remove that and install brass fitting that came with the boost gauge. feel around for a spot on the back.. its looks wrong with all thoes T's.
some info here http://www.gadgetonline.com/Super.htm
__________________
84 longbed p/u, scrappile 96 limited 4runner, trd s/c, SAS, leafs, low, 35's Last edited by akaphilly; 01-03-2013 at 12:02 PM. |
#15 (permalink) |
Personal
Sales Rating: (0)
Just a thought, maybe Kuni might run the Vin # and at least give you any maintenance/warranty history. It might have some info that could help.
__________________
94 SR5 2wd PU Extra Cab 3vze 5SPD Bone Stock Clean 50 Ford Shoebox V8 Flatty/Slow Coming I BUILT MY BUSINESS!! |
#16 (permalink) |
Personal
Sales Rating: (0)
Just my $0.02, but it looks as if they might have just tapped into a vacuum line.
I just ran it past our MDT here at work. He thinks they tapped into a vacuum line to, especially if vacuums all your reading. I've seen guys tap into this port here to read boost before.
__________________
Never argue with an Idiot. They"ll bash you down to their level and beat you with experience.
RIP-'90 P/U, 3.0, K&N FIPK, Downey Headers, D-T Cat back, 281k miles Current-'98 T100, 3.4, TRD S/C, 5 spd, Toytec BJS & Shackles, K&N, Magnaflow, URD ST shifter, Marlin HD clutch, Rebuilt R150 with Marlin parts, Stubbs HD-SKO sliders, Rear True-trac. My build http://http://www.yotatech.com/f206/...-steve-221925/ Last edited by 250000_yota; 01-03-2013 at 02:42 PM. |
#17 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Sorry about the delayed response, been out of town with no internet access.
Hmmmm, I talked to the shop and they insisted it was done correctly, they were actually kind of jerks about it.... I see you are in Colorado, know of any good shops that can take a look at it? Quote:
#18 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
Any Colorado peeps recommend a great shop that knows their stuff that I can take it to? I feel like that is probably the best thing to do at this point. Last edited by Rockwell; 01-06-2013 at 09:40 PM. |
#19 (permalink) |
Personal
Sales Rating: (0)
Where do you live at, the guy I go to is wondrous and the guys he knows across the way are all turbo fiends.
| Tags |
| 125, 34, autometer, baja, boost, gauge, hook, line, port, readings, sc, scooter, supercharger, toyota, trd, vacum |
