Bodylift for 4th gens??
Old 10-25-2003, 08:40 AM
jgs9455's Avatar
Question Bodylift for 4th gens??
From those of you in the know, will it be possible to put a body lift on a '03-'04 4th gen 4Runner?
I believe the 4Runner is still body on frame and not unibody. If so is there anyone coming out with one? Maybe Roger Brown bodylifts? r.c.brown@ieee.org
http://4Crawler.cruiserpages.com/4x4...yLiftKit.shtml
I was wondering because I read the thread that talked about removing X-REAS and thought that might be a viable alternative. Run bigger tires, get some height increase, and keep the stock X-REAS suspension.
Old 10-26-2003, 12:21 AM
Good Times's Avatar
Have not heard of any companies out there that has any body lifts for the new 4th gen. Good luck finding anyone to do one (should be relatively easy).
Old 10-26-2003, 03:16 AM
RTdawgs's Avatar
contact roger brown.
i think any truck that has body mounts can be lifted using bigger blocks, but there might be some mjaor adjustments necessary for fuel lines, etc.
Old 10-26-2003, 11:37 AM
03_4x4Runner's Avatar
There is probably a lot of work that would have to be done for a body lift, The bumers would have to be raised to make it look correct, which would require some cutsom brackets
And like said above, many things would have to be extended.
A small (1in) body lift may be possible without too much trouble, I know on my wrangler i did a 1in, and all i really had to do was extend the steering shaft, but that was a much simpler car
kawazx636
10-06-2021 03:03 PM
Badlander
10-10-2015 08:05 PM
voiddweller
10-02-2015 07:47 AM
Rickstwowheels
09-29-2015 02:23 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: Bodylift for 4th gens??
