Body Won't come off frame???
Old 05-18-2005, 06:54 PM
Silver_Truck's Avatar
Hey guys...I'm trying to install my body lift today and ran into a problem...the cam won't come off the frame. It'll come off a little bit but it seems like the current mounts are just stretching and as i jack it higher the suspension just raises...thanks for any help.
Old 05-18-2005, 06:56 PM
jimbo74's Avatar
you need t otake the bolts out before you jack up anything......
they're out
Old 05-18-2005, 06:58 PM
jimbo74's Avatar
the body jsut sits on the mounts... if there is some rust holding it togetehr.. address that issue....
Old 05-18-2005, 08:24 PM
runnerboy97's Avatar
do you have all the body mount bolts loose? as in both sides of the truck. it should just lift up
Old 05-18-2005, 08:41 PM
colsoncj's Avatar
Big hammer works for rust issues quite well I've found
Old 05-18-2005, 09:37 PM
BajaRunner's Avatar
Make sure there aren't any connections in the way, and then just keep jacking...it will eventually come off.
I had the same problem. I had to put it down, jack it up, put it down, jack it up and finally the last time I just kept jacking like there was no tomorrow and it finally broke loose...
Old 05-18-2005, 09:55 PM
Tacoma Dude's Avatar
If it's rust, wouldn't a good soak in PB blaster be good enough to break it loose? I'm sure it'll be dependent on the amount of rust present...
Old 05-18-2005, 10:05 PM
jimbo74's Avatar
thats what worked for me and i had no problems installing my body lift... about 2 weeks before i did my bl, i hit all the body bolts with pb blaster everyday durning my lunch hour.....
Old 05-18-2005, 10:06 PM
KevyWevy's Avatar
but that could probably easily brake something if his suspension is coming off the ground. and then all of a suddent have the body flying off. i dunno. i would soak everything in pb blaster first, then put the bolts back on and drive around a bit to get the pb blaster to soak in better. i don't have any experience with body lifts tough.
Old 05-19-2005, 06:26 AM
I've soaked everything afew times and I'll hit them again today before school. As far as i can tell theres nothing else holding it down as all the bolts are loose. It looks like it just stretches the factory mounts as it comes up a little bit but the suspension goes up more.
Old 05-19-2005, 06:36 AM
colsoncj's Avatar
Id say keep soaking, then when you get a chance you might try heating the area around the mounts, and lightly tapping them with a hammer, while the body is lightly jacked up, to sorta impact jar the area to help break it free.
Old 05-19-2005, 07:15 AM
rugerm44's Avatar
body lift.
Only do one side at a time.This helps to keep the body and bed aligned on the frame.Save you some headaches down the road.
Old 05-19-2005, 07:23 AM
shazaam's Avatar
Did u disconnect the steering shaft, the front and the rear mounts? Put the jack near the mount your going to stick the spacer in and see if that helps
Old 05-19-2005, 07:54 AM
jimbo74's Avatar
the suspension is flexing when lifting the body? are you jacking it from the body or the frame?
Old 05-19-2005, 09:47 AM
4Crawler's Avatar
You will see the suspension unloading when you first start to lift the body. Why? You are removing the weight of the body from the frame (and suspension), less weight = higher ride height. At some point the suspension should stop rising and then just the body. If you have someone to help, poke around under the edge of the cab looking for things that seem to be stretching/pulling/or otherwise holding the two together. Common things are steering shaft, battery cables, ground straps, etc. Never heard of the body mounts rusting to the body, but I suppose it it possible. It could be that the cab bushings are damaged (rubber torn away from the steel shell it is molded inside) and you can seeing that happening. Look at the bottom side of the 4 main cab mount bushings and look for signs of tearing between the rubber and outer shell.
You might try putting a little upward tension on the mounts then use a long chisel or screwdriver to try and pry the top of the body mount off the bottom of the cab:
Old 05-19-2005, 11:26 AM
BajaRunner's Avatar
See thats the explaination I was trying to say...
Old 05-19-2005, 02:27 PM
Thanks for the input guys...a little more kroil and a few wacks with the hammer got it all apart...I've got the cab done now and will finish the bed when I get back from work
Old 05-19-2005, 06:09 PM
colsoncj's Avatar
Glad to hear man! Best of luck.... hammer fixes all
Old 05-19-2005, 07:43 PM
Anyone got any good advice on how to line up the bed with then cab? I can't get the stripes even close.
Quick Reply: Body Won't come off frame???
