| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
body vs suspension lift
#2 (permalink) |
get some longer shackles and some 25mm or 26mm torsion bars, that will compliment your 32s nicely.
__________________
Ryan New: 2008 4Runner Sport. Mild, not wild. Old: 2000 4Runner 305s, Locker, TJM, Warn, Skids, Sliders, SC |
#3 (permalink) |
Lift
I'm currently running stock torsion bars with a slight crank and PP Rear Coils. They are giving me between 1-1.5" of lift which clears the 32's except under full compression/full lock turn, then I get a slight rub.
I was pricing body and suspension lifts about a month ago. A body lift (2 or 3 inch) for my 4Runner is around $90 +$350 for installation including the bumper relocation brackets and parts to make my auto tranny work right. A 4" Trailmaster suspension lift is around $900 + $350 for installation including brake line extensions. They said I could get a 35" tire under that lift combination. I eventually want to go for a SAS, so I'll probably just go for the body lift and get HD torsion bars when I get a winch. I hope that info helps.:confused:
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#4 (permalink) |
I'm going with a suspension lift set-up that isn't too costly. I'm going to run 2.5" Cornfed spacers up-front on Bilstein shocks, and Downey 2.5" rear coils over the Bils. All in all including the shocks it's costing me about $700, but just the lift compontents are only about $450 or so. Now I got a heck of a deal on instalation, I met a guy at Merchants tire that is going to do my lift for me there for $120 and install my new 32x11.50s all at once, $575 for tires and install there, and $120 for lift install. not a bad deal if you ask me. If your wanting extra clearance for the tires I would go the body lift route b/c it's cheeper and does just the job of getting more tire clearance, but if you want some extra clearance all the way around for off-roading or w/e then go w/ a suspension lift. The only downfall of a body lift is that your frame is exposted, but that's nothing that a nice set of nerf bars can't cover up. Stay right at or under 3" w/ a suspension lift, things get complicted when they go over that, 2.5" gives me plenty of room to run up to 33s w/o a problem, maybe even bigger, and I don't have to extend the brake lines or anything just drope some brackets(this is according to the guy at Merchants who has done quite a few lifts). Hope some of that info helps.
P.S. You can pretty easily do a body lift on your own w/ a few friends, preferably strongs ones, but a suspension lift is a new game, you would need a friend that has done at least one b4 to make sure things go smoothly. I'm sure others will get in on this topic soon.
__________________
97' 4Runner LTD -With a few toys |
#5 (permalink) |
yea i think i will go body lift route, one i dont do extensive off roading or crawling. and two, with the extra money i can get a trd camshaft, and a few other gadets. if i lift my truck 3inchs (body) will i have problems with the shifters and the transfer case shifter? And one final question, has anyone every installed a cam? is it somthing for someone without all the mechanical know it all can do? Or those who installed pro, how much did you spend. I know the dealer wants 950 just to install that badboy, but not for that price.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Body and suspension lift are done | Guerrero | Offroad Tech | 34 | 03-25-2009 05:24 AM |
| How can I tell if my 4runner has a suspension or a body lift. | Lifted96 | 95.5-2004 Tacomas & 96-2002 4Runners | 23 | 08-03-2007 11:51 AM |
| Body and suspension lift are done | Guerrero | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 04-25-2005 04:20 PM |
| lift body or suspension | MellamoPOUND | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 10-09-2003 01:50 PM |
| Body & Suspension Lift | Cmar | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 09-26-2003 03:14 PM |
