Body Lift Removal
Body Lift Removal
Hi Guys,
I just bought a 4runner (A Black 1999 Highlander) and it has a 2.5 inch body lift which I don't like the looks of and in combination with the 3 inch suspension lift its all a bit too much so I want to remove the body lift. What I don't know is what I need to remove the lift (ie spacers and other things). Any links you can provide will be very helpful.
I'll post pics of it later once it gets back from Discount Tire
See below:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ11
and kit D, 0" for the stock length hardware:
- http://www.4crawler.com/4x4/ForSale/...shtml#GenIII.2
Kit D is the stock length hardware, if you want to simply remove the lift and re-use the stock body mount bushings, then kit D is what you need. If you want to replace the stock (rubber) body mount bushings, for example if the existing bushings are damaged, then order kit D+P.
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
Backcountry411
07-24-2015 08:06 AM
