Body lift only?
Body lift only?
I've just purchased a 3rd gen 4runner, would like to install 32 or 33 inch tires.
But realistically I will be using the vehicle more to access poorly maintained forestry roads and splash in some mud occasionally. Rather than any intense articulation.
would a 2 inch body lift be enough to squeeze in bigger tires?
32's will fit with no body lift.
33's start to run into issues, not all of which would be solved by a body lift. Depending on the actual tires, of course, but clearance vs. the front upper control arm might be an issue, unless you're talking pizza cutters.
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
Backcountry411
07-24-2015 08:06 AM
