Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Body lift installed!
__________________
'03 beauty of a white Tacoma, check it out: http://www.yotatech.com/f83/spindles.../#post50606613 "The fingers you have used to dial this number are too fat. For information on how you can obtain your own personal dialing wand, please mash your palm against the keypad now." |
#2 (permalink) |
Personal
Sales Rating: (0)
How about some pis of all that work?
__________________
Eric 2001 4Runner with stuff: http://www.ultimateyota.com/index.ph...6&topic=1098.0 |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
I'll get some tomorrow. It'll be much easier to show some of that crap than to try and describe it, lol.
__________________
#4 (permalink) |
Vendor
Sales Rating: (0)
same thing happened to me with the 2nd gear not engaging fully. heres a fix that worked for me, it was easy
![]() /f2/1998-4r-manual-transmission-help-needed-65574/ basically, redrill the 4 holes to where the boots do not restrict the shifters movement |
#5 (permalink) |
Personal
Sales Rating: (0)
I Love 5speeds but it sounds like the Auto BL's are a bit easier to adjust for.
__________________
#6 (permalink) |
Vendor
Sales Rating: (0)
on autos, i believe (at least in my experience) you still have to adjust the shifter a little (a nut that connects the stick to the tranny). its just one of those inconveniences that happens as a result of a body lift...
#7 (permalink) |
Personal
Sales Rating: (0)
Yeah on the autos there is a bolt/nut that connects the linkage and shifter and needs to be moved just a slight amount for a 1"BL. Easy day and could actually be adjusted a ton more which is kinda suprising.
__________________
#8 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks Garrett... I trimmed out some of the aluminum shift gate, then flipped the lower rubber boot upside down. It's retardedly brilliant, and it worked.
Just gotta get her offroad and test in real world situations!
__________________
#9 (permalink) |
Personal
Sales Rating: (0)
[OP]
Before (with the stock tires)
After (with Body Lift and 265 75 16s) A couple of notes to the body lift process: First off, RB did a great job detailing in his instructions what to expect from this job. But there were a couple of details that I failed to notice during the procedure. More careful work on my part would have helped. First off, I didn't notice the rubber flaps pinned inside the front wheelwells (I suppose they keep mud and water from splashing directly into the engine compartment) These are pinned with plastic round tabs to the frame rail and to the wheelwell (to the body) so they stretched as I lifted the cab, and eventually a couple of the tabs gave way. Currently they're still installed, but they flap freely in places. Do I need these? What has everybody else done with theirs? Secondly, I failed to notice the manner in which my ARE camper shell is curved at a forward angle over the back of the cab. As I lifted the cab, its rear roof contacted the topper and pushed it rearward, taking some paint off it in the process. The damage is now unnoticable; just a warning to others. Note that the bumper gaps will go away with my new bumbers, which will begin to be fabricated April 1. The wait is killing me!
__________________
'03 beauty of a white Tacoma, check it out: http://www.yotatech.com/f83/spindles.../#post50606613 "The fingers you have used to dial this number are too fat. For information on how you can obtain your own personal dialing wand, please mash your palm against the keypad now." Last edited by spindleshanks; 02-26-2006 at 06:26 PM. |
#10 (permalink) |
Vendor
Sales Rating: (0)
most people either buy new gap guards or use pond liner to make their own.
are you makin' the bumpers yourself? what are they gonna look like? |
#11 (permalink) |
Personal
Sales Rating: (0)
[OP]
Armorology in Colorado Springs is doing my front and rear bumpers and maybe sliders as well. The guy is booked solid. I scheduled back in early February, and the soonest I could get in was April 1. And I have to drive 2 hours to get there! lol. Ric's bumpers were fabbed by Armorology. My front will be similar to Ric's, with a winch and stinger. I like his work because he uses sheet steel and not just tube steel. Kind of like a hybrid bumper. The rear will be a real simple number, a lot like the Warn bumper available everywhere.
__________________
#12 (permalink) | |
Vendor
Sales Rating: (0)
Quote:
#13 (permalink) |
Personal
Sales Rating: (0)
[OP]
They sure do. Check out www.armorology.com. Good stuff.
__________________
#14 (permalink) |
Personal
Sales Rating: (0)
[OP]
Here are some more nugs of wisdom for anybody looking to install a body lift...
-Have ample tools. If you don't have air tools, make sure you have wrenches AND ratchets. Your sockets should include deep and shallow. I found that a good set of adaptors (3/8 to 1/2" adaptor and 1/2" to 3/8" adaptor) help make up for a lack of socket variety. I used the hell out of my ratcheting wrenches, too. Have a BREAKER BAR handy! -Prelube all the hardware days, weeks, even months in advance. I like PB Blaster better than WD40. My vehicle has absolutely NO rust, and the bolts still fought me after two weeks of soaking in lube. -And folks, get a high lift jack like RB recommends. My floor jack required up to 10 blocks of wood to bring it to the correct height, and, needless to say, this is very unsafe. -Whether or not you're using a 4Crawler body lift, you should download and print RB's install instructions from http://www.4crawler.com/4x4/ForSale/...ft_HowTo.shtml These instructions are very thorough, and if you read them through two or three full times before beginning the install, you will be exceptionally well prepared for the job. Hell, I highlighted certain parts of these instructions and took notes in the margins days before even opening my toolbox. Thanks 4Crawler! Hope this helps somebody somewhere! Good Luck.
__________________
'03 beauty of a white Tacoma, check it out: http://www.yotatech.com/f83/spindles.../#post50606613 "The fingers you have used to dial this number are too fat. For information on how you can obtain your own personal dialing wand, please mash your palm against the keypad now." Last edited by spindleshanks; 03-02-2006 at 10:58 AM. |
#15 (permalink) |
Personal
Sales Rating: (0)
So when does the suspension lift get installed?
__________________
97 4Runner SR5 Blue - 135k miles, E-Locker, Armorology front/rear bumpers & sliders, BudBuilt skidplate+belly, MTR 285/75/16s, 2" Tundra/OME Lift, 1" 4Crawler Bodylift, 1" diff drop, Black Aluminum Wheels, Cobra CB 04 Land Cruiser Grey - 90k miles, OME Lift, Slee Sliders, 35" Toyo Muds |
#16 (permalink) |
Personal
Sales Rating: (0)
[OP]
It's sitting in my garage right now....smartass
Here's the deal...I have OME shock absorbers for the rear, but really wanted to get a set of KYB Monomax shocks for the front. So I contacted my former KYB boss, who now no longer works there. He's in Indiana, and at his new job still calls on the same accounts he's sold KYB to for 30 years. So he says he can get me some free goods. Turns out, his friends' distribution center in Minn. has to source the shocks elsewhere, I'll have to pay some freight, and it's been months. Every time I'm ready to give up and just go out and buy a set, he calls and tells me "I didn't forget about you, they're on the way"... So I keep waiting and waiting. Doug at ToyTec e-mailed me a while back wondering if I had installed it yet and wanting some pics, too. The package I have consists of the OME 881 springs, Alcan AAL, OME rear shock absorbers, brake line extension, and front differential drop. I'm ready to roll on the installation, but circumstances won't allow it.
__________________
'03 beauty of a white Tacoma, check it out: http://www.yotatech.com/f83/spindles.../#post50606613 "The fingers you have used to dial this number are too fat. For information on how you can obtain your own personal dialing wand, please mash your palm against the keypad now." Last edited by spindleshanks; 03-02-2006 at 12:31 PM. |
| Tags |
| 1, 2, 4crawler, body, install, installation, installed, lift, rb, rg, yacoma, yotatech |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Body Lift Installed *pics* | HarrisonP | 95.5-2004 Tacomas & 96-2002 4Runners | 21 | 04-03-2008 06:46 PM |
| 2" body lift installed! | MillerPKA | 95.5-2004 Tacomas & 96-2002 4Runners | 33 | 07-20-2007 07:40 PM |
| body lift installed... ride is different??? | KyleT | 95.5-2004 Tacomas & 96-2002 4Runners | 23 | 10-02-2006 04:21 AM |
| installed my body lift.... | acid_burn | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 06-13-2003 03:07 PM |
| 2" RG Body Lift Installed! | dmode | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 05-28-2003 10:45 PM |
