Body lift fitted on Saturday
Old 03-10-2003, 10:06 AM
Luke's Avatar
Body lift fitted on Saturday (lots of pics)
Hey guys just wanted to post some pictures of my body lift installation that me and my brother in law fitted to my truck on Saturday. I went for a Performance Accessories 2" lift kit and was really pleased with how the whole job went. Heres the pictures ........
Before
During
Finished Result.....
I was a bit dubious about doing the install myself but Colin (Brother in law) was confident that we could do the job without any major hassles. As it turned out the only problem we had was refitting the bumper and having to adapt a plate that the steering shaft went through because the plate they sent in the kit was obviously not meant for a UK 4 runner. But nothing an angle grinder and a little patience couldnt solve...
The whole job took one complete day for 2 of us including having to cut the gear shifter and weld in a 2" extension.
Im really pleased with how it looks and love the fact that when getting out of the truck I now "drop down" out of it rather than get out
Cheers
Luke
PS I owe Colin (in the pictures) a massive thank you as without his help the kit would still be sitting there in my garage Cheers dude! I owe you a few
Old 03-10-2003, 10:21 AM
redrunner's Avatar
Nice lookin lift... Looks like you might be able to fit 33's on there now. I think a bodylift is going to be my next mod (put in the edelbrocks and downey HD's a few weeks ago and now I'm ready to go higher). Was modification to the steering shaft necessary at 2" or do you think that could've been skipped? Were there any other issues when installing the lift?
Old 03-10-2003, 10:30 AM
Luke's Avatar
Yeah the kit came with an extension which bolted in line down at the bottom end of the steering shaft and I believe it was necessary. Other than that I was just able to refit the fuel hose back on by the filler cap, any higher and it would have needed an extension piece in order to fit properly. I had to lift the positive battery cable up a bit in order to get it to fit back onto the battery terminal but that was really just a case of a gentle tug Other than that we just kept a good eye on stuff as we jacked and found that everything else could acommodate the 2" lift with no problems. Suprisingly easy really.
Hope this helps
Luke
Old 03-10-2003, 10:36 AM
atarinaper's Avatar
how much was the kit?
Old 03-10-2003, 11:01 AM
Luke's Avatar
$87.75 from performance products.com plus a ton of shipping and import taxes to get it into the UK (still cheaper than buying one over here though)
Heres the link
listed as a Eagle kit but received a PA kit
Old 03-11-2003, 06:54 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Hey Luke, I forgot to reply to this earlier.
The forum is awfully hard to keep up with these days
It looks killer.
I might try a 1" Roger Brown body lift one day if I can get someone to help me do it.
Old 03-11-2003, 06:58 PM
Vato Loco's Avatar
looks good! Those JDM corners look killer.
Old 03-12-2003, 04:10 AM
ravencr's Avatar
Do they make a 1" body lift for a 1998?
Chris
Old 03-12-2003, 07:08 AM
HBoss's Avatar
It looks AWSOME man! Lifted always looks better, and you must be happy with the higher approach/departure angles too.
Al
Old 03-12-2003, 08:01 AM
ravencr's Avatar
Hey Corey,
How do I find out about the Roger Brown 1" kit? I'm interested in 1", but probably not 2". Let me know if you have a chance!
Chris
Old 03-12-2003, 08:15 AM
Staff
Corey's Avatar
Look in our Vendor section on the main page here.
There are tons of links in there to places that make cool stuff for our Toys.
Look for the logo that says "4 Crawler" on it, and that is Roger Brown.
His is the 2nd link down.
Also he has a personal website with tons of tips, and it can be accessed from his 4 Crawler link.
Old 03-12-2003, 08:21 AM
ravencr's Avatar
Thanks for the info Corey! This forum rocks!
Chris
Old 03-12-2003, 08:31 AM
keisur's Avatar
I wish it was that easy for 3rd gens!!!
Old 03-12-2003, 01:29 PM
Wild_Bill's Avatar
It is.
Old 03-12-2003, 01:43 PM
HBoss's Avatar
Originally posted by Wild_Bill
It is.
What kind of 2" body lift are you using, Wild_Bill? From where & how much? That's exactly what I'm looking to do at some point.
Al
Old 03-12-2003, 02:04 PM
keisur's Avatar
Al
Me too. I've heard bad things about going more than 1" on the 3rd gen.
Old 03-12-2003, 05:24 PM
Wild_Bill's Avatar
Performance Accessories 2" kit for a 95 1/2 - 98 tacoma. Everything fits perfect except the front bumper brackets, but they're as easy to fab up as getting a square piece of steel and drilling four holes in them. Had to cut and extend the wires for the fuel tank, that was pretty easy, just flip up the drivers side rear seat and there is a cover allowing access to the wires. Had to cut my shift levers and get some 2" pieces (included with the kit) welded in. I don't know what's involved with an automatic. Installed complete kit by myself in about 6 hours, and I took my time.
"Bad things about more than 1 inch" - are sure you're referring to body lift? 1, 2, or 3" only differences is tendency to roll, cg.
Old 03-12-2003, 05:57 PM
keisur's Avatar
It is the bit about the shift lever that I was referring too since it will sit 2" lower and possibly hit the sides of the console.
I have a manual tranny too. do you have any pics of the install you can share? how about the fan shroud and radiator?
I used to work for Baker Oil Tools and made many trips up to their test rig for my designs in Bossier City. Just thought I'd tell you that.
Old 03-12-2003, 06:55 PM
Wild_Bill's Avatar
Hmm I had the 2" extensions welded in the shift levers, no problems with clearance or hitting the console whatsoever. The kit comes with brackets to drop the raditor shroud 2", also several brackets for different cable clamps, etc.
I'm not actually from Bossier, I'm in the air force and am currently stationed here at Barksdale.
If you're up for a drive this weekend there are several of us heading to Barnwell near Longview saturday, gonna be a good time.
Old 03-12-2003, 06:58 PM
Wild_Bill's Avatar
Hehe just checked out your website, forget about barnwell you wouldn't get very far in this
Quick Reply: Body lift fitted on Saturday
