Body lift for 2004 Tacoma
Old 08-29-2004, 07:15 PM
cajuncoontail's Avatar
I am looking to get a 3 inch body lift on a 2004 prerunner and I don't know what size tires and rims to go with. I talked to a 4 wheel drive shop and they said 33x12.50 would fit. That is the size I want to go with. I don't plan on taking this truck offroad I have a Jeep TJ that I use for that. Will these tires work.
Old 08-29-2004, 07:28 PM
01Mossy Oak edition's Avatar
Old 08-29-2004, 07:33 PM
boogyman's Avatar
Talking
you might rub with only 3" of lift.. you will almost definitely rub when the wheels are fully turned. Just something to look out for.
-Russell
Old 08-29-2004, 07:35 PM
Guest
oly884's Avatar
3 inch body lift is pushing it, especially with a spanking new truck.
Old 08-29-2004, 07:41 PM
So probably not a good idea to go with that....
Old 08-29-2004, 07:51 PM
Was just looking to get a little lift with bigger tires. So what size tires and rims would be good to go with a 3 inch body lift
Old 08-29-2004, 08:38 PM
265/75/ or 31-10.50s & no body lift
Old 08-29-2004, 09:43 PM
Tacoma Dude's Avatar
I'm not sure exactly how much lift I got - but the suspension install I did yesterday was a 3" Cornfed and Procomp AAL.
This is what my truck looks like with the 265/75/16
Just to add, my suspension is a bit sagging because of the extra weight and wear of 65K miles.
Old 08-30-2004, 02:56 AM
What size tires does that convert too 265/75/16 and do you have any problems with tires rubbing?
Old 08-30-2004, 12:34 PM
265/75 muds are equivalent to 32s, I believe...
Old 08-30-2004, 02:01 PM
Something else I forgot - I haven't regeared and I can feel a little sluggish accelerating and getting to passing speeds on the freeway. I read here that 32s are probably as high as you wanna go with stock gearing. Any larger and you'll be wanting to regear and recover your lost power.
Old 08-30-2004, 05:46 PM
boogyman's Avatar
Talking
i would stick with 32s if you only have 3" of lift. if you plan on getting a suspension lift in the near future, get the 33s. but as TacomaDude said, you may need to regear for the 33s.
-Russell
Flying91
45
04-11-2024 04:39 PM
smthwsn357
12-04-2023 02:08 AM
09-04-2015 09:27 AM
Backcountry411
07-24-2015 08:06 AM
akaphilly
07-09-2015 02:18 PM
Quick Reply: Body lift for 2004 Tacoma
