Blown Head Gasket!!!!!
Old 08-02-2005, 01:33 PM
4Runner 4Play's Avatar
Blown Head Gasket!!! ** Update**
Ahh Crap!!!! Long story short... I've been able to get it fixed under the recall from a while ago!! Sweet, eh? Well It's not done yet, but in the next couple of days. I do have some questions for you guys though. I should get some other things done while there at it. In regards to the recall, I know that "the campain covers all incidental repairs" I.E. Knock sensor, cuz when it's taken off it the wires will break because of the high heat enviroment. blah blah blah.... some other things to try to get changed,
1) Head gasket (no way, really?)
2) main head bolts
3) water pump
4) timing belt
5) idler pulley x 2
6) knock sensor assy.
7) o2 sensor
But do you guys think I could ask/ get these too?
1) fuel filter
2) radiator and hoses
3) misc. bearings
4) pcv valve
5) valve cover gaskets
6) cam seals
7) 48'' plasma t.v.
8) my very own Pam Anderson Look-alike servant
9) oem Toy E-Locker
10) 1 billion dollars (muaahhhaaaaa)
Thanks a bunch for any replies. If I can make this work out for the better of me that would be tickity boo!!
cheers, Lee Hathaway
Old 08-02-2005, 02:13 PM
Epic Ed's Avatar
The 48" Plasma is a bit overkill. 42" is plenty large in most 4Runners. Other than that, I'd say do what ever you can afford. You've already hit the major items, like the knock sensor, water pump, timing belt, etc. If you're ever going to do headers, now would be a good time.
Ed
Old 08-02-2005, 02:32 PM
axon's Avatar
just had mine done 4 months ago
I got a new EGR cause they damaged it
new fan shroud cause they broke it
new injectors
free oil but they charged me for the filter
Since it was apart I had them replace , for zero labor charges.
plug and wires
idler pulley
timing belt
water pump
radiator and hoses
I brought in my own parts execpt for the wires and timing belt.
Old 08-02-2005, 03:02 PM
Add on's for H/G Work
EGR Valve, good call.... but should it be done? Iam not sure if they ever "wear" out. I'll look into it. Thanks fer the replies guys. Makes me all tingly inside to know that someone cares hehehe
cheers, Lee (ONE LUCKY SOB) Hathaway
Old 08-02-2005, 03:15 PM
dragon564's Avatar
Thermostat.....easy to do on its own but what the hey you are in there already...
Old 08-02-2005, 03:57 PM
jimbo74's Avatar
the list looked good until after #6 on the secodn half... then it jsut gets all dumb... and you wont have the $ to pay for all that....
Old 08-02-2005, 08:05 PM
Bumpin' Yota's Avatar
Originally Posted by 4Runner 4Play
7) 48'' plasma t.v.
9) oem Toy E-Locker
If I can get even one of those 4 things ill have my HG repaired too and mine aint blown!! LOL
*knocks on wood*
Old 08-04-2005, 11:06 AM
Talking
Well so far it went in today, and everything looking good to go.
I've asked them to call me when they've got the plenum off because I'd like to Paint it black and then take a dremel to the "Toyota" part to make it look like bare metal. However, one of my buddies was trying to steer me away from the painting of it, because it might overheat more, i.e. bare metal cools faster than painted metal. Make sense? Anybody have experiance with this?
I've seen it done to a '92 4runner and apperently no problems. But thought I'd just check with you guys first.
Cheers, Lee Hathaway
Old 08-04-2005, 11:23 AM
Silver_Truck's Avatar
they should replace the cam seals and valve cover gaskets as you don't usually reuse a gasket. I dunno about the plenum I just had em strip the paint off of the tag on top so now its all silver.
Old 08-04-2005, 12:40 PM
Blair's Avatar
I got all that PLUS 7 and 8. But I gave them back, as I already had my own.
Old 08-04-2005, 03:18 PM
surf4runner's Avatar
yes. ever seen an air cooled engine (motorcycle) painted? exactly the reason why.
there are better servents available than #8
Old 08-09-2005, 12:12 PM
Post **Update**
Well she's getting it all done boys.... So happy to say that!! Head Gasket and labour is all paid for by the recall but the add on things that Iam getting done are as follows....
1)Timing belt $164.05
2)Upper and Lower T.B. Pulley $437.48
3)Pcv valve $11.13
4)Idler arm $350.60
5)Used exhaust mainfold $175.00
Total: $1138.26 + tax Can.
Not too bad cosidering it all....I was going to he water pump while Iam at it, but I just cant afford another $250.00. They even wanted to charge me for the head bolts, 16 of em at $19.20 a piece!!! $300.00?!? I think not. Iam not 100% sure how difficult changing the water pump but if it's anything like changing the thermostat, It's realtivley "easy". I think...
Anyways, let me know what you guys think....
Old 08-09-2005, 01:58 PM
Epic Ed's Avatar
That's a lot of $$ for the parts. I hope that includes labor costs for those items. $250 for a water pump?! Wow -- that's robbery. I'd wait to do it on your own for that cost, too. It's not exactly "easy" but manageable for a guy with average ability and tools.
And you could save yourself about $300 by doing the idler arm repair yourself:
http://www.4x4wire.com/toyota/maintenance/idler/
Then, you could also saved yourself the $$ they want for the exhaust manifold and buy some Downey headers!
Savings:
$325 -- if you do the idle arm bushings yourself
$175 -- by not buying a used exhaust manifold
____
$500 -- to spend on new headers! Labor to do this will never be easier or cheaper than right now, with the engine out.
Ed
Old 08-10-2005, 09:51 AM
Yup, one more update....
Hey Epic Ed, good call on the downey headers.... I would love to get them. However, $ is running out. You know, as soon as anybody starts a Yotatech, the wallet lightening begins I was interested in NOT doing the water pump because it would cost an extra $250.00. Looking into it a bit more, I realized that in order to change it, the timing belt has to be takin off. Well I cant do that. So, I guess that it'll be done too.... aw well. So just to reiterate....
if you head gasket goes, get EVERYTHING done!! But you all knew that right?
Hahahaha!
p.s. I bought the '93 full load w/ leather for 8 grand can.
I've just realized I've put in $10,300 can. in it.
This better be it for repairs
Old 08-10-2005, 10:21 AM
Blair's Avatar
Don't pay for head bolts. They are covered under the recall. And make sure you get a rental while it's in. Also, ensure that they actually put a straight edge to the deck. There are run-out limits and you MAY ge the long block out of it.
Old 08-10-2005, 12:36 PM
Epic Ed's Avatar
Ah, but Lee, I'm showing you where you can get the money for those headers, bro. Any chance you'd feel up to tackling the idler arm bushings yourself? That's a $300 savings!
Ed
Old 08-11-2005, 09:03 AM
Ah, Ed.... How can I express the thanks that I want to show you Via a computer? maybe? How bout I buy ya a
Thanks for the heads up on the idler arm bushings. I did some research and decided to tackle it myself.... It aint that hard after all!!! So yeah, saved $325!! Where's that going to?..... Downey headers!!! woo hoo!! Well Iam not getting them just yet, their on hold fer now.... but I can understand why now would be pefect, it's just the timing is not right.
So again, big thanks man, And to all the rest of the guys a Yotatech.....
Well, Big thanks too!! I'll fill you all in with the rest of the story as it goes along.
Cheers, Lee (a little bit richer)Hathaway
Old 08-11-2005, 10:39 AM
Epic Ed's Avatar
Nice! Good call. Keep us posted as this progresses.
Ed
Old 03-28-2009, 06:58 PM
RandyatBBY's Avatar
Heck for $100.00 more I just put a brand new motor in my 85 4Runner
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
4x4-runner
12-27-2016 01:58 PM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Blown Head Gasket!!!!!
