Blown axle seals, how safe to drive? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 08-10-2007, 12:57 PM   #1
Bad axle seals, how safe to drive?
So, I've got bad rear axle seals on both sides of my car, I wont be able to fix them for another two weeks, how safe is it for me to drive my 4runner until then? It looks like it has gotten into the brakes but I've not really noticed any difference in the brake performance. So will I be able to safely go the next two weeks without replacing the seals and rear brake parts or should I do it now?
Griffeycom is offline   Reply With Quote
Old 08-10-2007, 01:12 PM   #2
mjwalfredo's Avatar
I have been driving the same way for about as long as you plan to and the brakes still work well. I have been sure to check the oil level in the axle housing every once in a while and add a bit whenever it gets low. If you think your axle bearings are still good then I wouldn't drive it, the gear oil has washed out the grease in mine and I can hear a whirring noise @ 50mph now. If you are going to replace the bearings, you should be fine as long as you make sure that you are not running too low on oil.
mjwalfredo is offline   Reply With Quote
Old 08-10-2007, 01:26 PM   #3
Okay, I've just got some oil and plan on adding some tonight and then taking it with me (I'm actually moving ~2 hours away for school, but will be home in 2 weeks) I was planning on changing out everything back there just in case anyway since parts aren't extremely pricey (I don't think, I'll reprice them when I get back home tonight).
87 22r rebuild issue bigjstang 86-95 Trucks & 4Runners 14 12-09-2016 10:16 PM
88 Pickup Transmission Swap mskalmus 86-95 Trucks & 4Runners 6 03-21-2016 12:41 PM
FS[PacSouthWest]: 2- 8"3rd members:4.88 ratchet lockers,new setup kit, rear axle rebuild kit,diff armor jerusry Axles - Suspensions - Tires - Wheels 1 10-19-2015 06:28 PM
Leaking extention housing seal andrewtexas123 86-95 Trucks & 4Runners 3 07-14-2015 05:29 AM
Removing CV with manual hubs ItsJustD 95.5-2004 Tacomas & 96-2002 4Runners 4 07-07-2015 08:49 AM
Tags
4runner, axel, axil, axle, bad, blown, dangerous, drive, driving, long, rear, safe, safge, seal, seals
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
