| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Block heater question?
__________________
Pioneer HU, Audiobahn 10.100watt Sub, Sirius, Cobra NWWXST CB W/ K40, Wolo Air horn, K&N FIPK,Tokico Trekmasters,Tundra TRDs, Revtec spacers w/extended studs,Energy bushings on steering rack /front swaybar,SS front diff. drop kit w/skid plate mod,OME 890 Rears with OEM LC Tokicos,Ebrake ext. bracket, BFG AT/KO's, ProComp 1078 Alloys, Magnaflow SS muffler, Hayden 1678 Tranny Cooler, 85watt Amber fogs, 7 Way R/V plugin. |
#2 (permalink) |
Staff
I would'nt go aftermarket on one of these... Toyota makes a very good and powerful one and sells it at a very good price with a warrenty and everything... the install is simple you remove one of the frost plugs and replace it with the heater but it's best to let a pro do this I think because you need to drain the coolant and disposing of the used stuff is a hazmat PITA.
Hope this helped aviator
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom centre console, stereo upgrade tinted windows Founding member 1972TLC fan club - Get well soon Mary Toyota Hilux... Get in or Get out of the way. |
#3 (permalink) |
I too am interested in this mod, can one of these just be picked up at a Toyota dealer...?
__________________
1997 Toyota 4runner 4x4, 2.7L, Auto, 146k miles, KC Slimlites, Bilsteins, OME 881/890s, Custom Westin Push Bar, Brembo/Hawk Pads, Yakima Gear, Midland CB, 265/75/16 Bridgestone Revos, Limited 5-spoke rims (Custom),Herculined Rocker Panels, Diff. Breather mod,Deckplate mod,4.56 gearing, Pioneer head unit w/Ipod connection and Sirius Sat. Radio. |
#4 (permalink) | |
Quote:
#5 (permalink) |
I'm going to check into this. Thanks! And by the way Mudferret, this is the second day in a row I've heard something about Yellowknife? I saw this on Ebay. http://cgi.ebay.com/ebaymotors/1982-...QQcmdZViewItem
__________________
#6 (permalink) | |
Quote:
#7 (permalink) |
I just bought a Toyota engine block heater, and installed it myself. Ten years ago, it was about $15.00 for the heater. It installs in the rearmost freeze plug position on the left (Drivers side) of the block. I should add that this applies to the 5VZFE.
I don't have the part number anymore, but any Toyota dealer should be able to order it. Last edited by 02SE; 10-20-2007 at 02:32 PM. Reason: more info |
#8 (permalink) | |
Synthetinc oil make block heaters obsolete
Quote:
X100...Mud ferrat, "you had me with hello" Synthetinc oil does make block heaters 100% obsolete now. Here is the deal your car will "turn over" very quick with SYN OIL and maybe NOT AT ALL WITH CONVENTIONAL OIL in those temps. You can get stuck some where If you choose to run dino Juice in sub zero temperatures. Block heaters are a good concept YET it truely is not needed (with SYN). I don't want to sound like a "arrogant oil snob".... yet seriously, it becomes a safety issue for you and your family and NO ONE has any business running dino juice in sub zero temps.... of coarse, Unless you think severe engine wear is a good thing (untill the conventional oil warms up). Or you have a death wish or really love severe frost bite. food for thought FRODIN, if you run Syn you are good to go. "Friends don't let friends buy cheap oil" Last edited by icerunner; 10-20-2007 at 04:31 PM. |
#9 (permalink) |
Staff
Synthetic oil definitely makes a huge difference on ease of starting but the block heater also insures that you have awarm defrost air available almost immediately which means you are not stuck i the driveway idleing for 5-10 mins waiting for the windows to un fog [really bad for the environment] or else getting a draft on you neck trying to drive with the window open so it does'nt fog up as much...
another trick you can use is to try to park with the front of your car aginst a building/garage door/solid fence or even a snow pile/ if you stop the wind blowing through the radiator you will hold the heat in the engine longer [several hours] making it easier to start when you can't plug in...
__________________
#10 (permalink) |
Using a block heater in cold temps., also means an easier time for the battery when trying to crank the engine over. Additionally, it can improve fuel economy, because the engine is much closer to fully warmed-up. So it spends less time running with the richer fuel/air ratio necessary when the engine is cold.
It also means fewer emissions, because the Catalytic Converter will reach operating temp. sooner. |
#11 (permalink) | |
Quote:
That's a little bit of an exaggeration. I've run 5W-30 dino oil in winter up here in -40 C temps (BTW -40 is where degrees C = degrees F) and still had it crank over just fine (it takes a little longer to catch at those temps, but it will still fire up just fine). That being said and with all the other benefits that come from running synthetic oil (both summer and winter), I have since switched to running synthetic instead, year round.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#12 (permalink) |
Any word yet on whether these block heaters are still an option?
I'm hoping the 3.4L's would work on the 2.7L...if not it sounds like I should just go to syn. oil. Although, I'm a little reserved about this since my truck has 138000, I'd hate to have a leak show up now....
__________________
#13 (permalink) | |
Quote:
__________________
#14 (permalink) | |
Quote:
BTW: When I was younger i was stuck/stranded in a chicago winter running penzoil 10W-30 in my 86' Camero. COLD AS HELL! Never again, "M1 syn" all the way. Last edited by icerunner; 10-26-2007 at 01:49 PM. |
#15 (permalink) |
When you install the block heater, don't overtighten it or the little clamp deal may break off during heating and cooling cycles in the future, and blow out all your coolant.
Ask me how I know.....
__________________
Born with a steering wheel in my hands and gasoline in my veins........ |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Block heater leak | cormel | 86-95 Trucks & 4Runners | 0 | 03-06-2007 05:20 AM |
| Block heater question | 123c | 95.5-2004 Tacomas & 96-2002 4Runners | 25 | 10-14-2006 07:47 AM |
| block heater | 84pickup | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-24-2005 06:16 PM |
| Block heater install | rwmorrisonjr | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 01-14-2004 07:08 AM |
| Block Heater Question | Brendan | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 01-06-2004 08:11 PM |
