Blinker sound and clock dimming over and over
Old 09-22-2012, 10:00 AM
RockyMtnToy's Avatar
96 tacoma 3.4L
My truck started making a beeping sound like the blinker does, but the blinker isn't on and the clock dims like i'm turning my lights on and off. It will beep sometimes for a minute, other times for a second.
EDIT: The corner lights light up in tune with the beeping, along with the brake lights and the light that shines on the license plate.
If this isn't the right section lemme know, and i'll post it in the correct section. Thanks!
The blinking and beeping continue even with the key removed.
Old 09-23-2012, 12:49 PM
A friend mentioned it might be a ground wire, any thoughts?
Old 09-23-2012, 01:08 PM
habanero's Avatar
Something to do with the headlight switch or a bad relay or the hazards and clock wiring doing something it's not supposed to (next to each other on my 4Runner, dunno if yours is the same)? The only thing I know about electrical stuff is that I don't know about electrical stuff.
Consider this a bump.
Old 09-23-2012, 02:26 PM
Hadn't thought of a bad relay, thanks!
Old 09-24-2012, 09:33 PM
So I pulled an in-line fuse under the dash and the ticking and blinking stopped but I lost the instrument cluster light. Everything still worked, just no back light.
Old 09-25-2012, 12:04 PM
habanero's Avatar
So the clock and markers are working correctly but the back light's not?
Old 09-25-2012, 09:57 PM
Correct. I haven't done anything at all and now the backlight is working again.This whole thing has me and all my friends confused.
I forgot to mention the flashing and beeping will happen even with the key removed.
Old 09-25-2012, 10:27 PM
wyoming9's Avatar
Red face
Does this have a Alarm???
If it does I would check that out.
Sounds like an alarm issue to me.
These things can be a royal pain if you don`t have the remotes or any info about it.
Old 09-26-2012, 12:56 PM
I have a Viper alarm. I have a little tab that I swipe so I can start it. I have no info on it tho.
What would you suggest my next move would be?
EDIT: I feel stupid now, the back light was just the little knob turned all the way down...
RyanJ989
11
04-07-2021 09:41 AM
Anthony Lee Mathis
09-15-2015 07:22 AM
langry345
09-14-2015 03:36 PM
ac7822
09-11-2015 08:49 AM
seab1209
09-03-2015 05:41 PM
Quick Reply: Blinker sound and clock dimming over and over
