Black soot on dash
Old 03-17-2005, 04:39 AM
Beartracker's Avatar
Black soot on dash
My 2001 4x4 SR5 stepside Taco spends allot of time off road but I keep it clean by washing all the time . The air filter is changed every 3,000 miles and all mantenice is up to date. The truck looks close to new inside and out but it seems to be leaving little black specks or soot on the dash coming from the defrost ducks. There is no filter for that or my AC on this truck , this is the info I got from the owners manual. Any idea what could be causing this? It's not bad but you can see it after about a week of useing the heat or defrosters. Mike
Old 03-17-2005, 05:31 AM
91Toyota4x4's Avatar
My girlfriend's 2000 Solara does that, don't know what it is though. Hers seems to do it regaurdless if she has used the defrost recently. We live in FL so there are months at a time when the heat never comes on.
Old 03-17-2005, 06:13 AM
Jeffires's Avatar
It could be that foam crap that insulates the AC ducts got pinched in there and is blowing out as it breaks down. I've seen this on an American make.
Old 03-17-2005, 07:33 AM
Thanks Jeff, that makes sense. Looks like 91 toy and I have something to check anyway. Mike
Old 03-17-2005, 01:52 PM
FORANA's Avatar
Yep I think that's what it is. The foam insulation is breaking down. I had that happen to my previous truck. Unfortunatley it doesn't stop till the foam completely wears out. You could change them if you wanted......
Old 03-17-2005, 02:18 PM
Does anyone know how to get at that foam? I looked under the dash at the heater vents but can't see anything. What do I have to take apart to get to it? Thank's for any info you may have. Mike
Old 03-17-2005, 02:38 PM
slustan's Avatar
all the heater vents are press fit, mine kinda wore down to, ya actually have to pull them apart and it should be in between the two pieces, sorry i cant be more specific im sure someone else can, but its not that difficult to do, just can be a pain to get to some areas, good luck though, somethign i should prolly look at doin myself.
Old 03-17-2005, 02:40 PM
Bob_98SR5's Avatar
bear,
look in the tech section and look for slc punk's write up on how to remove the center radio panel. it should be fairly close to your taco.
there is a main duct there in the center. you can probably see the vent that pushes the air upwards on your window
bob
Old 03-17-2005, 03:29 PM
Thank's guy's . I'll find it now.
Old 03-17-2005, 04:44 PM
I ain't diggin way down into that deep ass car dash just to fix some foam
She can live with it
Old 03-17-2005, 05:53 PM
91 Toy,Lol. I won't tell her you said that ;0) Mike
Jdgarrison
10-01-2015 05:22 PM
JHalcyonM
09-14-2015 01:10 AM
zz_denis
09-06-2015 03:43 PM
May-39
09-06-2015 01:05 PM
LJR
09-05-2015 06:02 AM
Quick Reply: Black soot on dash
