| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Black Exhaust Pipe, Low mileage, Squealing, Funky Exhaust
#2 (permalink) |
sounds like the o2 sensor just went sour
how many km's? and CEL? |
#3 (permalink) |
BC, how do I know the O2 sensor is bad? What's a good test for this?
Also, what about the chirping sound? It happens only when I'm moving. When I move slowly, it chirps every five to ten feet or so (didn't really measure), as if there were a bad spot on a pulley or something. Any ideas on the noise? I'm not exactly sure how many km's, but it's got 146k miles, which is what, 243 km's? There's not CEL blinking, but I did order an Auterra scan tool setup on eBay. Maybe that will help somewhere. It's supposed to have a pseudo-dyno built in. -d Last edited by daytraitors; 05-20-2007 at 08:35 PM. |
#4 (permalink) |
if the exhaust pipe is black then your running lean and it could be either your MAF needs to be cleaned, your A/F sensor needs to be replaced, or your cat could need to be replaced. it should throw a code fairly soon if your truck is running poorly.
__________________
Kyle 2002 4Runner - Lifted/Locked/Armored/Charged - 145k Miles 2007 4Runner V8 Sport Edition 4WD 20k Miles Buy My Stuff!!! http://www.yotatech.com/f109/97-4run...rt-out-151470/ |
#5 (permalink) |
Did you mean to say "rich?" Black "soot" in the exhaust pipe is a sign of a too rich condition, which would explain the bad mpg.
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#6 (permalink) |
perhaps i did, ive never been able to remember which is which all i know is that when i got the code pulled and it was a p0420 it said bank 1 system 1 system too lean and my exhaust pipe was very sooty
__________________
#7 (permalink) |
I'll wait 'til my Auterra comes. Should be less than a week away. But, there is no CEL. Will the scan tool tell me anything?
-d |
#8 (permalink) |
It might. It just depends if the system has anything stored or not.
__________________
#9 (permalink) |
Hmm. . . do you mean that I shouldn't have pulled the EFI fuse last night in a desperate attempt at maybe getting better mileage?
Will resetting the ECU erase any of these stored messages? -- I was reading another post about someone's crappy 3.slow. He said his calipers were out of alignment and killing his mileage. Could this be the cause of my noise and mileage problems? -d Last edited by daytraitors; 05-21-2007 at 09:32 AM. |
#10 (permalink) |
If your calipers were rubbing your brakes would be red hot and you'd smell it. I guess anything is possible though.
As for pulling the fuse - I am not sure. I don't think that resets stored codes; you have to pull the NEG on the battery to do that I believe. It sounds like you track your mpg. Did you change anything on the vehicle about when you saw a step-function down in your mpg?
__________________
#11 (permalink) |
No, You did not erase any codes and if by chance you did they will come right back if you have a problem and it sounds like you do. When my pipe turned black, mileage went way down it wasn't long before the light came on and after checking it the code was for the A/F sensor on the manifold. It cost me $130.00 and about 20 min. to replace it. Problem solved ! It took about 50 miles before it started running great again and the mileage was greatly improved. It's also a good time to clean the amf and the throttle body.
Don't use anymore Sea Foam for now. It sounds like you have run plenty through that system. Next time just add a bottle of Tectron to the gas and it will run like a scared rabbit and clean everything at once. The cost of the sensor depends on what year your vehicle is and if it's a 4x4 or not. They are not cheap but the book says they should be replaced every 75,000 miles. Hard to say what the chearp is , may be a belt or pulley. If you have never replaced the timing belt then you are over due for that too. Mike
__________________
2001 Tacoma SR5 4x4 , step side, 2.7 , extended cab, Auto. Mobile 1 syn 5w30 , Valvoline 75-90 syn in front and rear diffs and transfer case. Factory 16" wheels ,31" Wild Country TXR 265/75/R16, Aluminum Betterbuilt bed tool box, CB , 55W Halogen light mounted on tool box for back up, Elbow air box mod, 2 500 Hella running lights, Nissan Clinometers/Altimiter custom mounted on dash with red back lights.Red dome and mapp light. |
#12 (permalink) |
I'm going to try changing the front pads and rotors to see if that solves the squeal. I think it's the problem.
As for the mileage, after I pulled the EFI fuse, I drove 31 miles on 1.57 gallons, so over this very small sample size, my mileage went back up. I wonder if it's because the ECU hasn't had enough time to recalibrate itself to the bad (?) O2 sensor. As far as any major changes since mileage suffered, everything is mostly stock, as described above. -d Last edited by daytraitors; 05-21-2007 at 07:32 PM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| HELP exhaust muffler and pipe problem | silversup | 86-95 Trucks & 4Runners | 1 | 12-23-2006 02:44 PM |
| chop exhaust pipe? | bktaco | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 09-21-2006 04:45 PM |
| exhaust crossover pipe removal | 93X-Cab Mon | 86-95 Trucks & 4Runners | 11 | 02-23-2006 08:41 PM |
| expand exhaust pipe? | shazaam | Tool Time | 6 | 01-14-2006 04:07 PM |
| Need an Exhaust cross-over pipe from a 3.0 | Doc279 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 02-14-2005 07:46 AM |
