Biggest tires
32's will work if you pound the fender seam up a bit. 33's will work on stock rims as long as the fender seams are pounded and there is a 1" body lift. These are minimums obviously. To compromise you can put on a 265/75r16 tire which is about 31.6" high but the same width as a 31x10.50r15. Obviously that requires a wheel change but I'm just giving you some options.
Originally posted by jx94148
32s will rub but just a little. 31s won't.
When turning and front suspension is flexing it will rub the back of the front fenders, pretty much where you and your passengers feet are. Firewall neighborhood.
Rear?
I have the PP springs with 32's and have never had any rubbing in the rear. I have had a little up front (only under full stuff). Nothing major, no damage, just a slight rub.
Not all 32" tires are created equal. Some measure out to be more like 31.25" Width and wheel backspacing has a lot to do with it to.
I run Goodyear MT/Rs 32x11.5 x15 on 15x7 JJ stock wheels with 1.5 inch bodylift and low profile bumpstops. At full steering lock and suspension stuffed I rubbed. I sliced a 3x3x4 triangle off of the plastic lining and there is no more rub.
So I guess the answer on 32s is maybe. Hope that helps.
djpg2000
11-11-2020 04:56 AM
