Bigger brakes on 1st gen
Old 11-23-2005, 07:26 AM
JEDI87's Avatar
I just got my 87 runner back from the shop for brakes as I haven't had time in months,and the tech said that I have aftermarket or brakes from a 2nd gen on it.Is there a difference in them?He said the ones that are on it are bigger than stock.None of the parts he pulled for an 87 fit.
Old 11-23-2005, 02:31 PM
squishy321's Avatar
i know the 2nd gen runners have thicker rotors on them so they need a bigger caliper but i thought the pads were the same and the calipers were exactly the same dimensions except they were wider. I dunno though they could be completely different. Is it possible you have a 2nd gen rotor on there.
Old 11-23-2005, 03:26 PM
waskillywabbit's Avatar
Doesn't sound like much of a tech. Ask the P.O.
Old 11-23-2005, 03:32 PM
JamesD's Avatar
Originally Posted by JEDI87
I just got my 87 runner back from the shop for brakes as I haven't had time in months,and the tech said that I have aftermarket or brakes from a 2nd gen brakes on it.Is there a difference in them?He said the ones that are on it are bigger than stock.None of the parts he pulled for an 87 fit.
The only thing I can think of is that you have V6 brakes. I'am not aware of any aftermarket brake upgrades for our trucks.
James
Old 11-23-2005, 04:53 PM
JEDI87's Avatar
He said something about a 91 so maybe they are from a v6.He said the calipers were bigger than the 87's.
Old 11-23-2005, 05:56 PM
squishy321's Avatar
i have a 93 runner and tried to use the calipers from a 87 but they werent wide enough, but it looked like the brake pads would fit because the calipers were the same shape and what not, but 87 pads might not fit a 91 caliper if that is what you have.
Old 11-23-2005, 07:48 PM
kyle_22r's Avatar
i'm pretty sure you can swap in the V6 calipers with bigger pistons.
Old 11-23-2005, 07:50 PM
JEDI87's Avatar
Yeah,that's probably what happened.They were on it when I got it so I wasn't sure.I guess it's better since I have the bigger tires.
06-01-2021 01:51 PM
vanion2
07-29-2015 06:17 PM
harrisdawg
07-26-2015 09:42 AM
noahstancik
07-17-2015 05:38 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: Bigger brakes on 1st gen
