Big 3 Upgrade on 97 4Runner Questions
So my positive battery terminal looks like a fire hazard with wires for my amp, aux backup light, upgraded headlight wiring harness, etc and I want to clean it up.
I thought I would do the big 3 upgrade at the same time. However, I am still a little unclear on which wires I need to upgrade.
Here is what I think I need to do:
Alternator to Battery Positive
Battery Negative to engine block (underneath the oil filter)
Battery Negative to body (short wire going to inner fender near battery negative)
Back of Engine block to body (on cowl)
I am just confused because that ends up being 4 wires instead of 3. Should I do all 4 anyway or am I not thinking about this correctly?
Also, can anyone suggest a good positive terminal that will cleanly accommodate all of those wires?
Thanks.
Thanks.
here's what i did get your self some marine style terminals... for the positive get a inline fuse holder like the ones for a amp... now the grounds if u look straight down on the frame there should be a bolt for a bracket on top sand the frame good and use that bolt... for the 2nd run it to the alternator bracket the fender ground can be upgraded if u choose to do so
More grounds the better.
necessary are engine to battery, battery to body.
The one on the cowl is just a little guy... you can upgrade it if you like, but it's not nearly as important as the main ones.
Thanks for the replies.
I think it is debatable as to whether this mod is worth it. If you have a high output alternator and lots of lights / amps or other things that draw a lot of current then it seems to be worth it. If your truck is stock then it probably doesn't do much.
I've got a 125watt 4 channel amp and an aux backup light and 55/100 watt headlight bulbs. It seems like all the lights on my truck just aren't as bright as they originally were when I bought it so I am going to try this upgrade out.
From the12volt.com:
Definition: the "Big Three" upgrade means improving the current capacity of three cables: 1) alternator positive to battery positive, 2) battery negative to chassis, and 3) engine ground to chassis.˟ Some people replace the factory wiring; others add additional cables to the factory wiring.˟ This instruction is to add cables to existing OEM wiring.
That description confuses me when I think about the wires on my 4runner. 1 is clear. 2, I assume is the short wire from battery negative to the fender. 3, I thought was the small wire going to the cowl from the back of the engine.
To me it seems like the electrical system Toyota used on the 4runner doesn't quite match the description on the 12volt.com.
If anyone can explain the way the Toyota design relates to that description, that would help me understand what I am about to do much better.
1 Post
The big 3 are big on 2nd gens because the wire they used was a little thin.
The big 3 are actually just the 3 grounds. Battery to body, battery to engine, body to frame. I will say that the battery to body wire is a little thin on our 3rd gens. That is one that should be upgraded.
Yeah, the battery neg. to body is wimpy.
I guess that I want to do this upgrade because I feel like the OEM connections look pretty weathered and I just feel like they could use some R&R..
So, the OEM wires are pretty decent on the 3rd Gen?
Run 4 gauge everywhere.
Everyone hates a bad ground.
the stock alternator cable is decent, the engine ground is good, but the body ground is not. I still put 2x engine grounds in, just to be safe.
Definition: the "Big Three" upgrade means improving the current capacity of three cables: 1) alternator positive to battery positive, 2) battery negative to chassis, and 3) engine ground to chassis. Some people replace the factory wiring; others add additional cables to the factory wiring.
06-01-2021 01:51 PM
TURBOrunnerNM
07-22-2015 11:01 AM
Vargntucson
07-04-2015 12:15 PM
