Beware the trailer light controller
Old 05-31-2009, 09:47 PM
Parker Runner's Avatar
I am getting the 4runner for my trailer towing trip this weekend. In preparation, I hooked the trailer up to my 4runner and ....no lights. Lame.
I decided at that point to mount my RV flat trailer harness in the bumper vs. below it. A sawzall and drill later...the deed was done. But still now...only parking lights.....hmm.....
No power to harness. Not good.
I had truck lights, but no trailer lights. Remove bolts on left side where harness enters the "guts" of the 4runner.
Alas! A "trailer controller and fuse protector" or some other crap. Anyway, this little dude essentially is a giant fusable link for all 4 inputs. Anyway, after 10 years of bumping etc...it was no longer functioning. As much as I wanted a fuse between the trailer and truck....really? How much danger is there? Some...but in the end...
The controller was tossed and the wires were hardwired. It is all very clean now...and working!
So, if you have no lights...and is seems you are getting no power to the harness....check there.
Old 06-04-2009, 10:38 AM
Ron Helmuth's Avatar
I have a thread going on this over in "General Electrical"
You'll need the taillight converter box, as you need to combine 5 functions into 4 wires of the trailer 4 pin connector. Like you I also thought I could just splice this 4 pin into the existing but it did not quite work out.
Hopkins makes a good set of products to solve this. The taillight converter is Yota specific.
You may now have your brakes wired up to your parking lights, you will know from the inside if you step on the brakes and the dash lights up.
Old 06-04-2009, 10:41 AM
zlathim's Avatar
He's right.
The adapter is necessary.
Old 06-04-2009, 05:16 PM
[He's right.
The adapter is necessary.[/QUOTE]
thanks sir, there is not many things I can truly say with conviction but I do know my tail light converters now....
Old 06-04-2009, 05:53 PM
Gerdo's Avatar
My factory converter went out a few years ago also. I scraped it and went with an aftermarket one. All is good now.
Old 06-04-2009, 08:16 PM
Mtn Mike's Avatar
I had to replace my factory controller too. The worst part was removing all the molding!
Old 06-05-2009, 06:06 AM
gpcollen1's Avatar
Plenty of threads on these. Etrailer has them for about $30 for the complete harness...
Old 06-10-2009, 09:53 PM
Well, I learned something the hard way. The cruise control will not work with the lights on now. I am thinking the cruise gets the signal through through one of these wires. Given that the parking lights and brake lights are now wired together....I am guessing a little crossing is going on. Way to go toyota...
Anyway, off to etrailers...
Old 06-12-2009, 09:09 PM
oops yeah I forgot to mention the cruise control. It's sensitive to even a bad bulb.
Good to have these guys helping along the way.
I still did a number on my moulding pieces removing and replacing them. Those weird slide in push in inserts aaagggh
Old 07-18-2009, 06:43 PM
To update this thread...and I completely screwed up...you will lose brake lights as well.
How much does that suck?
Old 07-21-2009, 06:55 AM
gpcollen1's Avatar
Moral of the Story - Do a search on YT prior to making repairs...
Enjoy!
Old 07-21-2009, 07:29 AM
scuba's Avatar
I ripped mine out while starting my bed bob.
I threw it in the trash.
I think the the trash truck actually just came.
Charecter1
11-06-2023 10:08 AM
kirkrunner
07-27-2015 07:59 PM
shadowbirdie
07-21-2015 10:38 PM
rushw
07-18-2015 01:46 PM
toyota32
07-06-2015 05:42 PM
Quick Reply: Beware the trailer light controller
